Wifi is unstable, yet ethernet cable is top speed?
    Windows 8 64 bit
    Hey guys!
    This issue is most puzzling to me.
    Since yesterday the internet began to act unsoundly (through WiFi). As in I never had this problem before. There were periods where it was fast enough to play some online games, watch Youtube no problem, and then it would shut off randomly. So since yesterday I have been restarting the modem with only very short term resolutions to the issue.
    I accessed the modem through my web browser and it says the connection is always working fine. Despite that, I called my ISP and they claimed there was an issue, and forwarded it to Deutsche Telekom. Since then I did some experimenting and plugged my computer into the modem with the ethernet cable.
    Boom. No problem whatsoever. It's been top speed and reliable.
    So I'm assuming this is an issue with Windows 8, hopefully you guys can help me out!
    If it helps, I downloaded and installed updates for Windows today. There are 18 optional ones that I did not download yet, but I did download and install the important ones no problem. I checked the network adapters and they all state "The best driver for your software is already installed."
    Thanks in advance.
    You may want to go to the website of the laptop's manufacturer and download the latest driver, and install it. Using the OEM driver, sometimes eliminates the problem.
    Quote Originally Posted by Cabinet View Post
    Hey guys!
    Thanks in advance.
    You really should install inSSIDer WiFi scanner to check the wireless landscape in your area. Channel overlap is a common problem in most area's, inSSIDer allows you to choose the best possible channel based on what inSSIDer shows in your area.
    Click where it says "direct download link".
    inSSIDer - Free download and software reviews - CNET Download.com
I got home and turned on pc, got message that windows is finishing update and once i got to desktop, none of my usb devices worked, and even my internet disconnected. Restarting does nothing, and theres only so little i can do since keyboard and mouse are not working.
Won't detect the ethernet cable. in Network & Sharing
Hello, I'm currently trying to setup my router as the previous one broke but my laptop won't detect the ethernet cable being plugged in. Things I've tried: Rebooting and hard resetting router. Changing the Speed/Duplex. Changing to to 100Mbps Full Duplex caused the routers lan port to...
Hello everyone! So I've had this problem before and I went to a PC-Shop that fixed it by putting another driver on the PC. But now I have a new PC and after 6 months without any problems Windows suddenly decides there is no ethernet cable plugged in the PC. I've googled for hours and hours...
The cable works on a different computer, the computer gets wireless fine (typing to you from it) but will not read an ethernet cable. The motherboard manual (built the PC myself from components) says an LED should light-up if an ethernet cable is connected, no such LED appears when I connect the...
Hello Eight-forums, Since I installed Windows 8.1, my download speed gets huge drops. My ping and upload speeds are fine, but only my download speed has problems. I am using a wireless network adapter: Asus PCE-N15. Before I installed W8.1, I had no issues at all with it. I already tried...
I have Laptop and Desktop (windows 7 ultimate) I use it to play games, But I wanna transfer my Games (files) to my new laptop using Ethernet Cable or Crossover cable. I lost my 16 gb USB so I just transfer via Ethernet Cable but How? Please help me.
Friends on my Compaq DC7600 with a typical Broadcom ethernet controller, running Windows 8 Enterprise RTM 32-bit, the network performance is unreliable. With my windows 7 hdd in and running its flawless. If I still a USB wireless device in and run it to the same access point as is hosting the...
