Why is my wireless slower than my wired connection?
    Windows 8.1 Pro WMC
    I just installed a new wireless ac adapter and I do get a 1.3Gbps connection to my router. However when I test this connection by transferring some large files I get about 350Mbps for sending and 600 Mbps for receiving. When I transfer the same files with a 1Gbps wired connection I get about 970Mbps for sending (I think that includes some caching) and 760 Mbps for receiving.
    Are there some options in Windows 8.1 Pro that can be set to get better wireless performance?
    You may get a much better explanation than mine but a wireless connection generally has overhead because of the need for encryption. From my experience wired has always been (at least a bit) faster than wireless. I wish I had your problems.
    Yes these slow wireless connections are simply terrible.
    No magic button fix or real options for this although I would expect the wireless to be a bit slower and even with the 1.3GB speeds you still might need to get through another A/P or switch at 1GB.
    You might try working with the advanced settings for the wireless AC NIC in Device Manger.
    I think that actual throughput is supposed to be closer to 480Mbps even with a wired connection but it looks like a bit faster is possible from what the Op posted. Maybe I should measure this on my network.
    Typically with wireless you would get maybe 1/2 the actual throughput compared to what the status is showing.
    Maybe you can find more answers in the link which talks about wireless ac and it's potential.
    In perfect conditions, close to the access point, a three-stream 11ac radio can achieve the maximum raw data rate of 1.3Gbps. But no users will actually realize that in terms of useable throughput. "Typically, if the client is close to the access point, you can expect to lose about 40% of the overall raw bit rate due to protocol overhead acknowledgements, setup, beaconing and so on,"
    802.11ac 'gigabit Wi-Fi' starts to show potential, limits - Computerworld
    Windows 8, Kali
    Change the channel if you are in a crowded wireless zone
    Windows 8.1 Pro WMC
    Quote Originally Posted by my2cents View Post
    Thanks, I did forget that the wireless connection requires security which may slow things down.
    Windows 8.1 Pro WMC
    I did look at that and there are a ton of options there. I will start to look for a thread on how these options should be set, Asus provides no information.
    When transferring large files from one computer to another with a wired connection I can get very high speeds and the network utilization is greater than 90%. What I find strange is the transferring the file from one hard drive to another in the same machine is slower.
    I have moved that machine so that the signal travels through a couple of walls and the connection has dropped to around 877.5 Mbps to 1Gbps. When I transferred a bunch of files the average speed was 350Mbps and network utilization approx. 37%.
    Thanks for that link.
    Windows 8.1 Pro WMC
    Quote Originally Posted by Surgikill View Post
    Live in an apartment building surrounded by other apartments buildings and my system can see a lot of wireless connections but none in the 5Ghz range. I will try some different channels and disable everything but the ac connection and see if that changes anything for me.
    Quote Originally Posted by alkaufmann View Post
    I'm honestly surprised that you can achieve 877.5Mbps going through a couple walls with 5Ghz frequency which typically doesn't go through walls worth a darn, at least that is how it works for me and everyone else, many complaints about this although the 2.4Ghz frequency has no problems with a few walls.
    I get the same 877.5Mbps but my access point "Asus AC66U" is mounted outside my house under the eves while the client is 35 feet away across my yard with only a few palm trees in the way.
    Still it's a very fast connection and HD streaming works great and I can run multiple YouTube vid's without problems.
I recently updated from Windows 8 Pro to Windows 8.1 using Microsoft update. After the update was completed, I've started to have problems connecting to the internet using a wired connection. NOTHING else has changed since the update. If I reboot, it works for less than 30 minutes and then the...
Hi, I'm alright with technology but I've come across a problem I cannot solve. About two weeks ago I turned my laptop on and everything went blank, it couldn't read my drives, no data, nothing. After rebooting it a few times (with a lot of swearing and threatening to chuck it out of the...
So just this past weekend I re-installed Windows 8.1 on my dad's ASUS Notebook (K55N), but now its WiFi internet speed is a good ~25% slower vs wired directly to the router (Linksys E4200), that was definitely not the case prior to the fresh install. I did run Windows Update just after the install...
I've been having trouble with my internet connection for the past few days. It seems to be a battle between my router and modem, but my question is about the sidebar on windows 8. When I click on the internet connection icon (?) in the lower right hand corner, the sidebar appears, showing the...
Hello I just got my new computer today and first thing I did after setting it all up was try and connect to the internet. I plugged in my ethernet cable I would only get "Limited Access" to the router I've spent the last 10hours+ trying to find a solution but not a single has worked and i'm out...
hello when i connect my hp probook 4520s to my sony vpcyb4ajg with Ethernet cable on my Hp wireless disconnects and can not be connected until i disconnect lan cable. but on my sony i have both wired and wireless connections simultaneously hp:win8 x64 realteck Ethernet and atheros wireless sony:...
Wired Ethernet connection Problem in Network & Sharing
Hi, I've installed Win8 to my laptop and tried to connect to our dormitory network. First, it has been working pretty well.. ..but since this morning*) I cant connect. The troubleshooter ends without success displaying: "Wired ehernet connection doesnt have valid IP configuration." I'm...
