Wireless Connection problem with hidden SSID
    Hi guys,
    I'm a IT Support in our company, and currently I'm facing a problem on one of the staff's laptop for connecting to our internal wireless network that is hidden. The connection are configured correctly and in fact the laptop can connect to the wireless network correctly without any problem on last week, but today it just stopped working (even detecting) that particular wireless network.
    It can detect all other wireless network and even another hidden SSID. There are multiple laptops of the same model, and all of them are working fine except the only one laptop that are having problem.
    The model of the laptop is HP Probook 4440s running Windows 8.
    The AP we used are Cisco Aironet 1131 with Cisco WLC 4402.
    Any help would be greatly appreciated.
    Regards,
    Darren
    Windows 8 Pro
    Probably obvious (and already done) , you've removed all wifi connections totally from the laptops configuration and re-added that one again manually?
    Quote Originally Posted by Wullail View Post
    Thanks for your reply and yes, it has been done.
    I deleted the connections with the cmd and re-added it once again but still with the same result.
    Windows 8 Pro
    Just going through the obvious here...
    Do the protocols on the adapter being used match what is installed on the other laptops?
    (When I used to do IT support , I often had a user saying 'no , no , I didn't change anything' ...but.... )
    The protocols are the same.
    Windows 8 Pro
    The only thing I can think of is it's at the wifi router end , something may have changed there...perhaps the MAC for that laptop was blocked from accessing the wifi network for some reason?
Please can you assist with my wireless connection issue. I have just recently purchased the RTL8192CE wireless Lan 802.11 PCI-E NIC and installed it in my shuttle XPC. I am using Windows 8.1 64bit OS. The LAN card is picking up my wireless router fine, but when I enter my router password an...
Wireless connection troubles in Network & Sharing
Just bought a new Gateway desktop with Windows 8 and can't maintain wireless internet connection. Connects sometimes, but drops unexpectedly Sometimes says it can't connect, but does anyway and works fine Sometimes it can't see any networks Usually can only see my network, though I am in a...
Hi, Just got my new Acer laptop going. Then I wanted to connect to my router with another laptop (running Win XP) but didn't get connected. When I turned off the internet connection of the new laptop running Win 8, restarted my router then it was possible to get a connection. Also with another...
I prefer to keep my home WiFi network from public view by disabling the SSID broadcast, i.e "hiding" the network. With two modem/routers (a Belkin Play Max F7D4401 ADSL modem/router and now a Cisco EPC2325 DOCSIS modem/router) on two computers (home-built desktop and Acer TM8172T notebook),...
hello when i connect my hp probook 4520s to my sony vpcyb4ajg with Ethernet cable on my Hp wireless disconnects and can not be connected until i disconnect lan cable. but on my sony i have both wired and wireless connections simultaneously hp:win8 x64 realteck Ethernet and atheros wireless sony:...
Today the laptop with 8 suddenly cant find my home network, not available in win8 or in the inssider program. I can see others, but not mine. Tried deleting the profile, netsh wlan delete profile “profile name” then add it again but no go. So, i started another laptop with a fresh win 8...
I successfully setup Windows 8 Consumer Preview and correctly setup and connected to an existing and working hidden wireless network. This network is hidden for a reason and working with all other devices. How can I configure W8 to automatically connect to this network when in range? I was...
