WIFI problem - kindly help
    Pakistan
    Hi, I have Latitude D630 having "Dell Wireless 1490 Dual Band WLAN Mini-Card"
    problem is whenever i try to connect through wifi, the system freezes, it happens only when i connect through wifi, the wifi adapter works on window 7.
    another problem is that i have G945 intel graphic card. windows update installed the latest version of the driver but it wasn't working, specially games weren't working, now i installed old version of the driver (which was for windows 7) and everything is just fine.
    but unable to find wifi driver.
    Thanks.
    If you can find a Windows 7 driver for the Dell 1490 mini card then try installing it in compatibility mode for Windows 7.
    I don't really see any Windows 8 specific drivers for this.
    Pakistan
    I cant find anywhere.... i searched many times on google and found some, but when tried to install them, some error appears (i don't remember clearly) like installation package is corrupt. can you provide me link please.
    Thanks for reply.
    That system was made for XP, try getting a different updated version of pci NIC card and installing it.
    The drivers from Dell aren't up to date for this as expected.
    Drivers & Downloads | Dell US
Having problem on WiFi in Network & Sharing
I've two PCs in my home, one's a desktop and the other's a laptop. The desktop is connected to broadband through router(LAN) and the laptop is connected by wifi. In the desktop I get more than 200 kbps download speed on a direct download(Using IDM). But I get less than 50 kbps speed in my laptop...
Hi All, Win8: I have two wifi APs in the home and I have it all set up so that one is the Internet by cell phone tether and the other is the cabled network via the router wifi. Works just fine - except. On wifi 1, Internet I have it set for "Connect automatically" which at boot up it...
different wifi problem in Network & Sharing
I can connect to WiFi at my house, but get the limited problem at school. I did the netsh int TCP commands Any help is appreciated Thank you
Hi, I was a Windows 7 user and yesterday I installed Win 8.1 Pro, which I purchased almost a month ago, just didn't have the time to install (it was better that I didn't have any time) and since then I can't figure out lot of things, one of which is really disgusting. See that my mom and I use the...
Solved wifi problem in Network & Sharing
my wifi on my laptop keeps acting up. at a random time the wifi bar in the lower right hand side turns to a yellow exclamation mark over it, after hovering over it it says 'limited'. usually if i just turn off the wifi then immediately on again it will sort it out. cant work out if its a driver...
Wifi problem in Network & Sharing
i am able to connect to my wifi at home. but, when im trying to connect to the wifi in my school it is saying wifi do not have a valid configuration. please help me.
I install windows 8 pro 64 bit and i dont have wifi (on/off) . When i connect my ethernet cable i have internet connection . But without cable i cant connect wireless . I dont download drivers because i dont know how . Please help !!!:confused:
