ralink wireless lan card problem
vagzagor
i have an asus desktop.after the windows update i've lost my wifi card.it says that the windows cannot install the drivers.my router is checked.i try to download the drivers directly from asus but the problem still. i dont know what to do anymore.
Try doing a system restore back to before you downloaded the downdates that messed you up, then refrain from downloading any RAlink drivers in the future unless they come FROM Ralink.
    AMD 4400+/4200+
    2 GB/3GB
    GeForce 8400 GS/GeForce 210
    Hitachi 40" LCD HDTV
    "1842 x 1036"
    WD My Book 1140 USB Device
    Works 550w
    MSI "M-Box"
    Water Cooled
    Dell Keyboard
    Microsoft Intellimouse
    Cable Medium Speed
    Chrome/IE 10
    Eset NOD32 6.x/Win Defend
