wired connection prevents wireless connection
    hello
    when i connect my hp probook 4520s to my sony vpcyb4ajg with Ethernet cable on my Hp wireless disconnects and can not be connected until i disconnect lan cable. but on my sony i have both wired and wireless connections simultaneously
    hp:win8 x64 realteck Ethernet and atheros wireless
    sony: win 7 x86 atheros Ethernet atheros wireless
    There is a setting to disable in the group policy editor, minimize the number of connections, under Administrative Templates, Network, Network Connections.
    there's not such a setting there
    neither in user config nor in computer config
    would you be a dear and give more detail?
    thanks
    Quote Originally Posted by hagimostafa View Post
    hello
    It may look like the Sony is using both connections but it's not, it's using the wired one.
    The analogy that well if one machine is doing this then why isn't the other doesn't really work with computers.
    In fact my own machine maintains a wired and wireless connection but the wireless only works if I unplug the wired connection.
    You can be connected to both but the wired connection will win out every time.
    If you really want the machine to use more than one connection you can try the connectify dispatch software, it still only chooses the best connection to use at any given time.
    Connectify - Turn your PC into a Wi-Fi Hotspot and Get Faster Internet
    There is also a Group Policy setting for using two connections but I'm not sure how it works. A while back I took the time to look up this policy just in case somebody wanted to try it.
    Attached Thumbnails Attached Thumbnails Group Policy for using two connections at once.PNG
    Yes. I have the same situation as Chev, on a Dell laptop. Even through the docking station, it shows both wireless and ether as working, but only the Ethernet is, in fact, operational. Quite an advantage through a docking station, I disconnect and am , unbroken, back on wireless.
    to prevent any misunderstanding let me describe the situation in other terms.
    i have an adsl wireless modem, both laptops connect to internet through this modem via wireless connection. some times when i need to transfer large amount of data between to laptops i connects these two by a ethernet cable. after connecting two laptop to each other sony still has internet connection but hp is disconnected!
    also in notification area sony shows wireless icon connected with internet access but hp shows wired icon with red warning which says no internet access.
    so i guess it is impossible for sony to access internet through hp! and also it doesn't seem to be normal and hp has a problem in configs!
    i just unchecked lan/wlan switching in bios setting and built in device section. now everything is working nice and smooth.
I recently updated from Windows 8 Pro to Windows 8.1 using Microsoft update. After the update was completed, I've started to have problems connecting to the internet using a wired connection. NOTHING else has changed since the update. If I reboot, it works for less than 30 minutes and then the...
Hi, I'm alright with technology but I've come across a problem I cannot solve. About two weeks ago I turned my laptop on and everything went blank, it couldn't read my drives, no data, nothing. After rebooting it a few times (with a lot of swearing and threatening to chuck it out of the...
Hi again ....am now aware that normal booting only achievable when my USB printer is disconnected. Can't begin to understand what is happening here. Asus P8Z68-VLX / Intel i3 2120 / Win 8 Pro 64
I just installed a new wireless ac adapter and I do get a 1.3Gbps connection to my router. However when I test this connection by transferring some large files I get about 350Mbps for sending and 600 Mbps for receiving. When I transfer the same files with a 1Gbps wired connection I get about...
I've been having trouble with my internet connection for the past few days. It seems to be a battle between my router and modem, but my question is about the sidebar on windows 8. When I click on the internet connection icon (?) in the lower right hand corner, the sidebar appears, showing the...
Hello I just got my new computer today and first thing I did after setting it all up was try and connect to the internet. I plugged in my ethernet cable I would only get "Limited Access" to the router I've spent the last 10hours+ trying to find a solution but not a single has worked and i'm out...
Wired Ethernet connection Problem in Network & Sharing
Hi, I've installed Win8 to my laptop and tried to connect to our dormitory network. First, it has been working pretty well.. ..but since this morning*) I cant connect. The troubleshooter ends without success displaying: "Wired ehernet connection doesnt have valid IP configuration." I'm...
