Wifi issues help!
Techwomen
I have been having problems with my wifi network, it cuts in and out all the time. I have to constantly use the troubleshooter to fix it. Here is the screen shot attachment I took for you.
    Microsoft Windows 8.1 64-bit 9600 Multiprocessor Free
    Hp Pavilllion 15-n230us
    Intel(R) Core(TM) i3-4005U CPU @ 1.70GHz
    Hewlett-Packard 2163
    2 gigs
    Intel(R) HD Graphics Family
    Realtek High Definition Audio
    1. Moble Pc Display
    1336X768 Recomended
    HGST HTS541075A9E680
    Coolsense version 2.2
    Standard PS/2 Keyboard
    Synaptics PS/2 Port touchpad
    60MB
    AVG
hi there stranger, sorry to hear your having probs. The detailed info link at the bottom of the page may shed some light on the problem. More than likely its a signal/channel issue. Placement of the adapter and router should be as high as possible and away from walls and shelves and windows, solid objects and metal frames can be contributors. A free program like inssider or xirrus wifi inspector will show you what channel all your neighbors are using, you want your router on one that is least used by neighbors. Microwaves and cordless phone bases shouldn't be close to adapter or router either. :geek:
My Computers
System One System Two
    17074 Pro
    HP dv7 3173nr
    M520
    5GB
    1600x900
    120Mb/s
  • PC2
    HP A12 R7 17074
I am at a friends house right now. So if I download one of those softwares it will tell me how to fix the issue?
    2 gigs
    1. Moble Pc Display
    1336X768 Recomended
    60MB
    AVG
If the issue is interference, the solution is changing the channel in the router wifi settings. The program will show you what channels are most used by your neighbors, you change to a diff channel, hopefully it stops dropping out.
My Computers
    17074 Pro
    HP dv7 3173nr
    M520
    5GB
    1600x900
    120Mb/s
  • PC2
    HP A12 R7 17074
Okay I downloaded it and it showed me what channel how do I change that on my windows 8 laptop?
    2 gigs
    1. Moble Pc Display
    1336X768 Recomended
    60MB
    AVG
    Custom build
    AMD Phenom II X 4 965 BE
    Gigabyte GA-MA790X-DS4
    G-Skill 8 GB PC 8500
    AMD XFX HD Radeon 6790D
    Realtek HD onboard
    2l Samsung SyncMaster S20B300
    1600 X 900
    Seagate Barracuda 320 GB w/OS
    Cooler Master Hyper212 120mm
    Logitech G510
    Razor DeathAdder 3.5
Well it is not my router it is my friends so not sure I should be changing her channels.
    2 gigs
    1. Moble Pc Display
    1336X768 Recomended
    60MB
    AVG
so,...are you telling us this router is not in your home? How far are you from the router, and what is the signal strength?
My Computers
    17074 Pro
    HP dv7 3173nr
    M520
    5GB
    1600x900
    120Mb/s
  • PC2
    HP A12 R7 17074
No this is not my router I am visiting a friend. I am in the next room to the room with the router.
    2 gigs
    1. Moble Pc Display
    1336X768 Recomended
    60MB
    AVG
have you checked at the laptop makers site for the most up to date driver for your adapter? Not a lot you can do if it isn't your router to adjust. :(
My Computers
    17074 Pro
    HP dv7 3173nr
    M520
    5GB
    1600x900
    120Mb/s
  • PC2
    HP A12 R7 17074
No not sure how to do that.Thanks for trying.
    2 gigs
    1. Moble Pc Display
    1336X768 Recomended
    60MB
    AVG
Okay I scanned for my laptop and have all these downloads but do not see a wifi one? Help HA HA!
    2 gigs
    1. Moble Pc Display
    1336X768 Recomended
    60MB
    AVG
Okay I downloaded drivers so we will see. Umm not sure I did it right. lol
    2 gigs
    1. Moble Pc Display
    1336X768 Recomended
    60MB
    AVG
