Low speed internet despite high speed provided by ISP
    Win 8 32-bit
    Dear friends
    Could you help me figure out why it is that I have trouble browsing in high speed despite the fact that the wireless adapter receives data at 1 Mbps minimum? I haven't been able to watch videos on Youtube, read the news etc because the browser takes ages to load the full page. I checked which applications are connected and they haven't exchanged much data as you can see below:
    Excuse my English!
    Thank you.
    Win 8 32-bit
    Any ideas?
    Thank you!
    Don't you think that running bit torrent in the back ground has something to do with this problem or is that just for testing connection?
    Between bit torrent and using an outdated wireless G connection you really can't expect much here, you may be paying for a faster service but the use of 802.11g is a bottle neck for this connection. Going to 802.11n router and wireless adaptor would be much better.
    Looking around for a better driver might help.
    Win 8 32-bit
    Quote Originally Posted by chev65 View Post
    I don't think Bit torrent has any influence here but it is OK. On the other hand, this router has always intrigued me, sometimes it works, other times it doesn't. It's an old Lynksys router that has worked for years now. I have a D-link N wireless adapter but I haven't noticed any improvements, to be honest, the built-in G adapter works a little 'faster'. I will see if I can convince the building manager to buy a new router, if that is possible at all.
    I'd say that in general you won't be having good connection speeds when running torrents with a wireless connection.
    If you have access to the router you can try changing wireless channels and use the non mixed mode 802.11g settings to improve things. Windows 8 will probably work better using WPA2 security with AES encryption.
    With wireless G connection speeds limited to 54Mbps you are short on bandwidth so going to wireless N hardware would probably improve things dramatically although you would need to use the wireless N only settings and use channel bonding.
    Windows 7
    If you are downloading or seeding in the bittorrent, it can make the browsing slow no matter how high speed the internet is.. If there is no activity going in the bittorrent client then in normal cases it won’t affect the browsing speed. It doesn't matter that you have an 802.11n wireless adapter if your router is old and supports only 802.11g. Your adapter can receives only what your router sends. Check if your router supports 802.11g wireless mode. As already mentioned in above comments try changing channel to one with least interference. Also check in a different wireless device. Also try re configuring the device. If still no improvement try to get a newer router from a friend , configure and try it. I think that will pinpoint the issue to, whether it is a router issue or internet service provider issue.
    Did you try Speedtest.net by Ookla - The Global Broadband Speed Test with and without torrent running ? What is the bandwidth your ISP promised ?
    1 Mbps may not (and it isn't) enough to watch higher resolution Youtube videos when doing just that, let alone downloading something else at same time.
What's your Internet Speed? in Network & Sharing
Speedtest.net - The Global Broadband Speed Test Mine from inside Windows 8 dev Preview 8102. 1703
More:FCC makes more spectrum available for high-speed Wi-Fi | ZDNet
so i ran a speed test with several different website and they all said my download speed is between 5 Mbps and 8 Mbps : 34005 however when i actually download something my download speed stay at 1 Mbps or when i watch videos ( youtube ) :cry: i dnt have this problem with my phone ! thank u
internet speed in Network & Sharing
hi everybody A HAPPY NEW YEAR TO EVERYBODY My internet speed seems to drop quite often, but if I turn my modem off and then back on the speed returns to normal, can anyone tell me why. regards calmat
Solved Internet speed issues in Network & Sharing
Hi , My internet speed has suddenly deteriorated from what it was. I had a steady 6-7 Mb/s down and 1 Mb/s up , but now I have a constant speed like this : 23153 I use a DGN 1000 , its around 2 years old .I have talked to my ISP (Talk Talk UK) and they tell me they do not support my router...
Hi all; Good day, I would like to know how to boost the read/ write speed of my Hard Disk Drive. Someone told me about some innovation in Windows 8 such as Superfetch, Prefetch, Ready Boost, etc - something that is supposedly utilizing the idle capacity of your RAM/ SSD to boost the read/ write...
very slow internet speed in Network & Sharing
I just brought a new Gateway desktop PC. It had Windows 8 preloaded on it. I am experiencing very slow internet speed. Does anyone have any suggestion on how I can fix this? Thank You!
