Problem with wireless streaming while using computer
    I cannot say with 100% certainty that this problem started when I upgraded to Windows 8, but it has just become a problem recently, so I suspect it is related to Windows 8. I have a server with Windows 2011, and I use it to store my DVD collection, and then I stream the videos using a Boxee. When my wife is using the Boxee to stream a DVD - or even the PS3 to watch something on Hulu Plus - if I'm playing a game on my computer, whatever stream she's watching hitches up and freezes and generally doesn't work. When I turn the game off, it works fine.
    I was under the impression that the wireless activity would just be handled by the router and my computer wouldn't be involved. I don't know much about networking, so I don't know how to fix this. I have the Windows 8 PC as a member of HomeGroup so I can access the server's files and make adjustments without having to remote to it - I have no idea if this is part of the problem, but I'm putting it out there as a potential part of the problem.
    Any suggestions anyone has would be very greatly appreciated.
    Win8.1 Pro 64bit
    Check the QoS(quality of Service) in the routers gui interface.
    Quote Originally Posted by fargofallout View Post
    The problem is that you are using up all the bandwidth on the wireless side, most of this can be avoided by properly tuning your wireless for maximum bandwidth.
    The thread below talks about this problem and how to tune your wireless.
    wifi status
I have tried everything. Updated drivers, downgraded drivers, tried drivers from another manufacturer, uninstalled and let it auto install the "correct" drivers. I changed my power settings to max performance, messed with the signal configuration and most recently, completely reset windows. ...
Wireless Streaming Software in Software and Apps
Hi all. I hope I picked the correct forum for this post. I have an LG Blu-ray player with my HD television in my living room. The Blu-ray player came with some software that you could install on your computer if you want to use the Blu-ray player's wireless capability to access files on your...
Attatched necessary zip. Not sure why it crashes when I stream something and do other multi-tasking activities. I think it's memory related though.
I had my media server DLEONSKIE-PC linked up for streaming from my libraries on this PC to VIERA E30, this worked no problem,this was prior to Installing Windows 8 a few months ago. I now cannot access my music library, but can access my pictures library. This now seems to be a very hit and miss...
Hi gang, I can place movies on a usb stick and stick it in my sony tv usb socket and watch the movies with no problem. My specific question is: Is it in any way possible to wirelessly stream videos from my win7/8 pcs to the sony tv, so that it thinks the incoming signal is just like there is...
hi, i just bought a 670 and am having trouble getting it to see MKV files i have on my computer. i can browse to the computer and open the folder i have the movies in but it keeps saying the folder is empty. i checked for firmware update and was told i have the latest one, i bought it used ...
In a magic trick that only geeks can pull off, researchers at MIT have found a method to let users click and scroll exactly the same way they would with a computer mouse, without the device actually being there. Cup your palm, move it around on a table and a cursor on the screen hovers. Tap on...
