Operating System Not Found problem. SONY Vaio SVF15A
    I was copying my files on a USB, then I took it out ( without safely removing) and went out. When i got back, the laptop has already shut itself. when i turn it on it goes Operatin System Not Found. I use windows 8.1 and only 1 hard drive. When the PC goes into VAIO care rescue mode everything is white with options like start BIOS steup, contact support, start from media .... etc which are not at all helpful, unlike others problems which makes the screen black. but the same thing happens to me when i change boot mode to Legacy, but back to normal when to UEFI. i don't have any disc. from what i know the product key is in the UEFI thingy in the computer.
    When I start BIOS setups it still shows
    System Memory : 12288mb
    Hard Disk Drive : 1000gb ( so i presume the hard drive still works)
    Methods that worked for others but not me :
    1. Taking out the HDD, give it a blow and put it back in.
    2. Changing Boot to legacy
    3. Changing the boot order to every combination i could.
    4. Use a program called Wondershare Liveboot.
    5. Reinstall windows 8.1 using a USB boot media, which was downloaded from microsoft home page.
    6. Using command promt from USB boot media /scannow
    the problem also lies in my little knowledge about computer matter. I couldn't find out if the HDD still works, what version or name it has, don't know how to update the bios as well. Please help me guys
    Austin TX metro area
    Do not remove usb sticks until given all-clear by Windows.
    "1. Taking out the HDD, give it a blow and put it back in." -- this could have caused more harm than good
    Quote Originally Posted by RolandJS View Post
    I saw people removing usb sticks al the time so i thought it didn't matter much. but should it even do anything to the hdd ?
    but is there a way to fix this ?
Hi, I'm trying to install windows 8.1 on a sony vaio E series laptop which had windows 8 preloaded on it. I made a bootable usb thumb drive with Windows USB CD/DVD Download tool. When i try to boot through the pdrive it doesn't boot. I selected the option to boot from external device and selected...
A friends laptop (sony vaio) with 8.1 installed, started giving the error operating system not found when trying to boot. I tried a sytem refresh with my windows 8.1 disc and it would boot from disc. After the system refresh it has gone back to windows 8 not windows 8.1 Im assuming that it...
I have windows 8 installed.I have Lenovo G570 laptop. Today I am getting an error "An operating system was not found". Since os was windows 8 I cannot access bios menu to change boot order. I am stuck. Please help!!!
operating system wasn't found in General Support
hi , yesterday i try to move memory from the D: drive to the main C: drive.. i use windows 8 and i try to do it with the partition of windows 8 (win tab +R). than i shrink the space of the D drive and cant move it to the C drive so finally i just take the shrinking memory and make new drive F.....
Hi Purchased a SVF1521P2EB from PC world. Trying to use a recovery program I always use for all my laptops and desktops and have created a bootable USB Stick and also a DVD bootable disk. Both disk and usb work on all other systems but this Sony Laptop.
Solved Operating system not found in General Support
a friend of mine had a dual boot of windows 7&8 then, he tried to remove windows 8( it's partition was active but windows 7 wasn't active), he first deleted win8 from msconfig then tried to delete the partition of windows 8( but Disk management didnt allow him neither easeus partition manager did,...
Hi all Finally got BOTH my Sony MMC stick AND the SD card to work (plus other drivers) on W8 Consumer preview All the drivers for this series of computers -- hard to find as they aren't on Sony support sites and I HATE those type of sites like DriverMax where they sucker you in with "Free...
