Problem installing from WES 8 CTP 32-bit bootable IBW
kmfraley
Hello all,
Not sure whether or not anyone in this forum can comment on Windows Embedded Standard 8 (WES 8), but just for grins I'll post. I'm trying to install from DVD onto my hardware platform using the 32-bit bootable IBW, but it always fails as follows. The black screen with the blue beta fish comes up, then the next thing I expect to see is the little animation with the tiny balls chasing one another in a tight circle (sorry, best description I could come up with) vertically below the fish. I never see the animation, instead the system just reboots. Can anyone help me with this or point me to some other place where I can get some help? Thanks.
Kris
TheWES 8 IBW is buggy - even if deploying a configuration file - it cannot match all the dependencies, calculate the OS footprint size, and takes forever. If you only have 30 days to evaluate the system you've created - it is not worth the time spent. Wait till they release something more competent - or move the modules to the WES 7 distribution share and try to build the setup you want that way - WES 7 at least worked properly. (I haven't a clue if this would succeed!!)
    HP COMPAQ Presario CQ57
    inbuilt
    4GB
    ATI
    notebook
    1366x768
    Seagate ST9500325AS
    Google drive 15GB
    Skydrive 25GB
    BT Cloud
    external 20v
    pretty good
    inbuilt
    touchpad
    Chrome Canary usually
    no Start menu modifications
