Need help! problem
    Need help! problem
    Hi, today i tried to install windows 8 pro VL. my Previous Os Was Windows 8 evaluation(the one From microsoft.com). I did full Install(not Upgrade). THe installation Was Going Well till the very Last step That Says "getting ready" and At that time my laptop Was Accidently turned Off... I tried To turn On Again but during The loading screen It says "The computer Restarted Unexpectedly Or Encountered An unexpected Problem, Windows Installation Cannot Proceed. To Install windows, click "OK" To Restart the Computer And Then Restart The Installation" i Clicked Ok And the computer restarted But meet The Same Error Every Time i Try to Boot My Windows... i Tried To boot From Disk too But Failed. Can anyone Help Me? I don't Have so much knowledge In Computer And Also My english Is not So Good. So Please Explain Clearly . Thanks a Lot.
    (Sorry For Random capslock )
    Windows 8 32bits
    ME, XP,Vista,Win7,Win8,Win8.1
    Where do you buy your Windows 8 pro VL DVD from?
    Microsoft Windows 8.1 Pro 64-bit
    Just boot again form the install dvd, remove the partitions and let windows recreate them while you reinstall it.
Need help! problem
Here is my problem When i write my DVD-R with Nero/Imgburn/Burnaware it says burnt successful but it fails to verify and even dvd is blank when i reinsert in laptop and my friends computer. I have tried to burnt at slower speeds but still same problem.:rolleyes: My dvd drive reads other DVDs...
When I try to check for a solution to a problem (Control Panel\System and Security\Action Center\Problem Reports) a warning appears telling me to connect to the Internet or to try later… 44832 The problem is that I am connected to the Internet while I receive this message and now I do not see...
I have 2 issues. I don't know if they are related somehow. 1. I installed PrivaZer and deleted it. It still shows up on the right click context menu. I tried to reinstall it and deleted it again. I still have that problem. I even restarted the computer. How can I get rid of the entry? 2....
So i'm trying to delete this file i have in my downloads folder, which is a normal .avi file. however, this file is really broken, it wont delete. I suspect this file makes my folder not showing thumbnails and acting slow and sometimes wont show anything at all, just a loading bar thing. i...
Hey, running Windows 8.1 64bit, Asrock Z87E-ITX mobo, Intel 4770K Problem 1: When i shot down my pc via windows Shot Down button pc doesn't go Off. I see Windows Off screen, screen goes black but pc still running. Solution? Problem 2: When my pc goes sleep or monitor goes sleep i can't...
I had no problems with Customer Preview, everything worked, but, I must say that this Release Preview is another story all together. My PC hardware configuration is unchanged since installing Windows 7 when it came on to the market. 1. Doing a clean install did not install a clean...
