Problem,removal disc shown when no drive conected
quickslvr
I have clean installed windows 8. when i explore computer to see the drive them in removable drive section, along with dvd drive there is removable drive too but it have not connected any drive like pen or flash drive. so how to remove it. help please
    win 8
What drive does it list as being removable?
    Windows 10 Education 64 Bit
    Asus
    Thermaltake TR 620
    Stock heatsink fan
    Logitech Wireless K350 Wave
    80 Mbps Down 30 Mbps Up
Do you have a card reader installed? Can you post a screen shot of what you're talking about?
    Custom build
    AMD Phenom II X 4 965 BE
    Gigabyte GA-MA790X-DS4
    G-Skill 8 GB PC 8500
    AMD XFX HD Radeon 6790D
    Realtek HD onboard
    2l Samsung SyncMaster S20B300
    1600 X 900
    Seagate Barracuda 320 GB w/OS
    Cooler Master Hyper212 120mm
    Logitech G510
    Razor DeathAdder 3.5
Try right clicking on the drive and selecting eject--even though there is no drive connected. Second, reinsert the drive, and try the same thing. Finally, do a restart--or do this step first if you want.
    ASUS P8P67 Deluxe Rev B3
    16 GB Corsair Vengeance
    EVGA 570 SC
    Gateway
    Dual Boot:
    Cooler Master 932 HAF
    Zalman CNPS9900MAX-B CPU Fan
in fact I have just installed windows 8 so no drivers are installed . card.PNG
    win 8
Use the snipping tool in Win8.
    EVGA 570 SC
    Gateway
    Dual Boot:
Got it. We were posting at the same time. Did you try the possibly simple fixes I mentioned above. Probably too simple to work.
    EVGA 570 SC
    Gateway
    Dual Boot:
don't know what I did followed u or not? I opened my computer and right clicked the removable drive and eject clicked and then inserted the pen drive which showed another disk I drive and did the eject in the same way \. and closed the window and restarted the pc but the same thing unsolved...is it the same what u said?
    win 8
Close enough.
    EVGA 570 SC
    Gateway
    Dual Boot:
to the experts and mvp.....please suggest me is the fault of pc? what if I leave that drive as it is ? does it harm my pc anyway/? I am terribly getting tension from this problem......what if I go to disk management and hide the drive?please help me
    win 8
Try right-clicking that Removable Drive and look at the Properties/Hardware Tab to see if it gives you any additional insight. You could also try Control Panel > Autoplay and set everything back to defaults.
Hello again quickslvr,
As stated previously, that removable media appearance in your computer folder is probably some necessary hardware that was detected during installation (like a card reader, etc) and, if you have read the above article, it could even be some weird "out of the ordinary" hardware like a USB hub on you monitor. Moreover, after reading that article thoroughly, I am in agreement with the author; in that, if you can't find it, don't do anything drastic to try and make it go away, because it is (more than likely) necessary hardware for your configuration (even though you don't know what it is yet). Now, I am basing my assumptions on the fact that you just did a clean install so that eliminates (in my mind) any user errors that could have been introduced over time.
However, I do have one more place for you to look and I apologize if this has already been suggested:
Relax...
