Sony VAIO T Series SVT13112FXS 13.3" dual boots problem
    WINDOWS 7 AND 8
    Hello all, I am very new to the forum
    I have a problem with dual boots. I created a USB boot drive and I was able to boot up into an install menu and up to the license agreement screen, and following screen.
    but unable to see any partitions that i'd like to installed windows 8. Any help is appreciated.
    thanks again!
    WINDOWS 7 AND 8
    here is the picture.
    Welcome to EightForums, TORO35.
    Go ahead and select custom install. The next screen screen should give you the choice of drives/partitions.
    WINDOWS 7 AND 8
    thanks for quick replied. I did that and it comes up with the following screen without any partitions. Please see the attached pictureClick image for larger version
    I have no problem with my other two computers and laptop (Toshiba). those computers and laptop are installed from DVD. Was that because I installed this laptop from USB Drive?
    Thanks again!
    Your quite welcome. I gues you were posting that last pic when I was posting. You were a bit faster.
    Not sure what the problem is. Kind of wierd that drives don't show up. Did you create the USB correctly? Please check it compared to this tutorial: Create Bootable USB or DVD with Windows 8 ISO
    Try clicking the Load Driver button.
    WINDOWS 7 AND 8
    I will re-create a USB boot drive again with the above instructions and try it again. will post result
    WINDOWS 7 AND 8
    Quote Originally Posted by MrShowdown View Post
    i did and it looks for the driver and i dont know that was that
    WINDOWS 7 AND 8
    when i clicked on the Load Driver button, it show the following picture and still dont see any partitions.
    WINDOWS 7 AND 8
    I did re-created USB boot drive with the above instructions. Same result.
    Any inputs, suggestions is greatly appreciated
Page 1 of 3 123 LastLast
Hi, I'm trying to install windows 8.1 on a sony vaio E series laptop which had windows 8 preloaded on it. I made a bootable usb thumb drive with Windows USB CD/DVD Download tool. When i try to boot through the pdrive it doesn't boot. I selected the option to boot from external device and selected...
Hi guys, New here so hi :) I'm having problems with my sony vaio connecting to the internet. For one thing it doesn't pick up wireless signal as far away as the other laptops in the house. The main problem though, is that often the bars will be lit up as if it is connected but there will be a...
Hi Purchased a SVF1521P2EB from PC world. Trying to use a recovery program I always use for all my laptops and desktops and have created a bootable USB Stick and also a DVD bootable disk. Both disk and usb work on all other systems but this Sony Laptop.
BSOD on Sony Vaio E series BAD_POOL_CALLER in BSOD Crashes and Debugging
Ive been having this issue usually when i leave my laptop sitting for a while and it just goes into sleep mode or whenever i close an re open the lid it will give me the same error message if someone could give me an idea of what the problem maybe thanks
Hello all! Thank you for your help in advance! My computer recently started displaying a Blue Screen of Death upon starting up Windows 8. It takes a really long time to start up, and then it goes to the BSOD and displays a message: DRIVER_POWER_STATE_FAILURE :cry: I tried the Windows 8...
Sony Vaio E Series Brightness Not Changing in Performance & Maintenance
Hey guys, I've only recently noticed this, but the brightness on my Vaio is stuck. FN+F5/6 does nothing at all. Changing the slider on both Win+C - Settings - Brightness and also through the Control Panel display options both do nothing either. Any suggestions how to get around this? ...
Hi all I've got a sony VAIO laptop with two slots on the front for SD/MMC cards and the sonu pro duo cards. Works perfectly on W7 but on W8 only the SD card is recognized -- I copied the drivers from W7 (at first W8 didn't recognize the card at all) but after installing only SD cards were...
