Solved Sony VAIO T Series SVT13112FXS 13.3" dual boots problem
TORO35
Hello all, I am very new to the forum
I have a problem with dual boots. I created a USB boot drive and I was able to boot up into an install menu and up to the license agreement screen, and following screen.
but unable to see any partitions that i'd like to installed windows 8. Any help is appreciated.
thanks again!
    WINDOWS 7 AND 8
Welcome to EightForums, TORO35.
Go ahead and select custom install. The next screen screen should give you the choice of drives/partitions.
    8.1 Pro X64
    Acer T690
    Intel Pentium D Dual Core
    Acer/Intel E946GZ
    2GB (max upgrade)
    Acer AL1917W A LCD
    1440 X 900
    Thumb drives
    Standard 250 watt
    Dual case fans + CPU fan
    Acer Windows PS/2
    Wireless Microsoft Arc
    54mbp/s
    IE11
    Defender
thanks for quick replied. I did that and it comes up with the following screen without any partitions. Please see the attached pictureIMG_0385.JPG
I have no problem with my other two computers and laptop (Toshiba). those computers and laptop are installed from DVD. Was that because I installed this laptop from USB Drive?
Thanks again!
    WINDOWS 7 AND 8
    8.1 Pro X64
    Acer T690
    Acer/Intel E946GZ
    2GB (max upgrade)
    Acer AL1917W A LCD
    1440 X 900
    Thumb drives
    Standard 250 watt
    Acer Windows PS/2
    54mbp/s
    IE11
    Defender
Try clicking the Load Driver button.
    Windows 10 Pro x64
    Lenovo Y520
    Intel Core i5 7300HQ
    OEM Lenovo
    4GB DDR4-2400
    NVIDIA GeForce GTX 1050
    Realtek HD
    Seagate 1TB 5400 RPM
    OEM Lenovo
    Logitech G502 Proteus Core
    100 Mbps
    PC:
    AMD Athlon X4 760K
    8GB DDR3-1866
    AMD Radeon RX 460
    Seagate 500 GB 7200 RPM
I will re-create a USB boot drive again with the above instructions and try it again. will post result
    WINDOWS 7 AND 8
I did re-created USB boot drive with the above instructions. Same result.
Any inputs, suggestions is greatly appreciated
    WINDOWS 7 AND 8
Just for grins, how about the refresh button?
    8.1 Pro X64
    Acer T690
    Acer/Intel E946GZ
    2GB (max upgrade)
    Acer AL1917W A LCD
    1440 X 900
    Thumb drives
    Standard 250 watt
    Acer Windows PS/2
    54mbp/s
    IE11
    Defender
You will need to find the driver for that system, however, I would have thought it might be a part of the Win8 install.
May want to contact Sony.
But you can also look Here for the driver yourself,, unfortunately I do not know which install you will need. I am not familiar with that model
It will need to reside on a USB device, such as the one that you have Windows 8 on, might work.
However, that system is supposed to fully support Win8
    Win 8.1 Pro
    Self Built
    I7-3770K
    ASUS SABERTOOTH Z77
    CORSAIR 8GB 2X4 D3 1866
    EVGA GTX680 4GB
    ASUS 24" LED VG248QE
    SAMSUNG E 256GB SSD 840 PRO -
    SAMSUNG E 120GB SSD840 -
    SEAGATE 1TB PIPELINE
    CORSAIR GS800
    CORSAIR 600T
    CORSAIR HYDRO H100I LIQUID COOLER
    THERMALTA CHALLENGER ULT GAME-KYBRD
    RAZER DEATHADDER GAME MS BLK-ED
    APC 1000VA -
    LGELECOEM LG 14X SATA BD BURNER -
    CORSAIR SP120 Fans x 3 -
    NZXT 5.25 USB3 BAY CARD READER -
    HAUPPAUGE COLOSSUS
I have thought of that, but dont know which drivers I need. I already have contacted Sony, but they said they dont support dual boot. I will try your link today when I go home.
thanks
    WINDOWS 7 AND 8
Driver link in post 13.
    ME, XP,Vista,Win7,Win8,Win8.1
    Notebooks x 3
    Desktops x 5
    Towers x 4
Yep, follow theog's links. That's what you need.
    Win 8.1 Pro
    Self Built
    I7-3770K
    ASUS SABERTOOTH Z77
    EVGA GTX680 4GB
    CORSAIR GS800
    CORSAIR 600T
    APC 1000VA -
    HAUPPAUGE COLOSSUS
You are welcome.
    Notebooks x 3
    Desktops x 5
    Towers x 4
