Sony VAIO T Series SVT13112FXS 13.3" dual boots problem
  1. #21
    windows7
    You can download your F6 drivers from here:
    Intel Download Center[/QUOTE]
    link is not working pleas ehelp
  2. #22
    windows7
    bro i have same problem but at the moments driver download link is not working please update it plz
  3. #23
    ME, XP,Vista,Win7,Win8,Win8.1
    Quote Originally Posted by samirdip View Post
    link is not working pleas ehelp[/QUOTE]
    Link is working fine.
    http://downloadcenter.intel.com/Sear...2F6+drivers%22
  4. #24
    windows7
    thanks for your prompt reply. i have tried but no one is working i have sonyvaio t series svt13113en please help and provide me accurate download link.
  5. #25
    windows7
    wait wait wait bro thanks it s working thanks for your help man thank you very much........ thanks bro
  6. #26
    Link is fine.
Page 3 of 3 FirstFirst 123
Hi, I'm trying to install windows 8.1 on a sony vaio E series laptop which had windows 8 preloaded on it. I made a bootable usb thumb drive with Windows USB CD/DVD Download tool. When i try to boot through the pdrive it doesn't boot. I selected the option to boot from external device and selected...
Hi guys, New here so hi :) I'm having problems with my sony vaio connecting to the internet. For one thing it doesn't pick up wireless signal as far away as the other laptops in the house. The main problem though, is that often the bars will be lit up as if it is connected but there will be a...
Hi Purchased a SVF1521P2EB from PC world. Trying to use a recovery program I always use for all my laptops and desktops and have created a bootable USB Stick and also a DVD bootable disk. Both disk and usb work on all other systems but this Sony Laptop.
BSOD on Sony Vaio E series BAD_POOL_CALLER in BSOD Crashes and Debugging
Ive been having this issue usually when i leave my laptop sitting for a while and it just goes into sleep mode or whenever i close an re open the lid it will give me the same error message if someone could give me an idea of what the problem maybe thanks
Hello all! Thank you for your help in advance! My computer recently started displaying a Blue Screen of Death upon starting up Windows 8. It takes a really long time to start up, and then it goes to the BSOD and displays a message: DRIVER_POWER_STATE_FAILURE :cry: I tried the Windows 8...
Sony Vaio E Series Brightness Not Changing in Performance & Maintenance
Hey guys, I've only recently noticed this, but the brightness on my Vaio is stuck. FN+F5/6 does nothing at all. Changing the slider on both Win+C - Settings - Brightness and also through the Control Panel display options both do nothing either. Any suggestions how to get around this? ...
Hi all I've got a sony VAIO laptop with two slots on the front for SD/MMC cards and the sonu pro duo cards. Works perfectly on W7 but on W8 only the SD card is recognized -- I copied the drivers from W7 (at first W8 didn't recognize the card at all) but after installing only SD cards were...
