Have a problem after upgrade the system to Win8 Pro from Win7 Home Pre
  1. #11
    Sydney, Nova Scotia, Canada
    Windows 10 Education 64 Bit
    I'm not running Avast but I did try turning off the Windows Firewall. The Weather Network App still won't work for me but I am glad you got all your apps to work. I guess I should mention I'm still running the Release Preview, not the final release.
  2. #12
    Perhaps this is why, I installed the final versions get from microsoft during the purchase.
    You perform a clean installation, it may well work.
  3. #13
    It looks to be a problem with all versions. There are several threads with the same or similar problem after upgrading to the final release. I won't be buying the current upgrade version offered for 40$. I don't plan on switching from Windows 7 to Windows 8 on any of my current PC's. When the Release Preview times out I'll just go back to Windows 7 on this PC. I boot up into Windows 7 more than I do 8 anyway. I'll probably go Windows 8 on my next build.
Page 2 of 2 FirstFirst 12
Solved Win7-Win8 upgrade Licensing in Installation & Setup
I have a test machine with win 7 on it. I also have an Win8 pro upgrade iso (bought just after win 8 RTM). The copies are older copies, before all the 'OEM only' nonsense. I need to have win 7 AND win 8.x on this test machine. What I'd like to do is clone the win 7 drive, upgrade to win 8...
Win7-Home -> Win7-Pro-Upgrade -> Win8-Pro-Upgrade -> Win8.1 Yes I had to go through that litany of upgrades to get to Win8.1 and I then installed a bunch of software on top. Then I wanted to use the Windows Hyper-V so I could get Ubuntu running also but it turns out that my Intel CPU Core 2 Duo...
Hi, Paid $39.99 to upgrade my Win7 Home Premium, burned it to disk. For some strange reason, the install is Win7. :confused: If it's a factor, have a dual boot with Ubantu. Any ideas of why this is happening?
I have windows 7 32 bit installed on 2 separate drives (dual boot). On one of the drives I want to install Windows 8, but want to use the 64 bit version to see if it runs a particular programme better taking advantage of more memory. According to MS upgrading using the Install Assistant or...
Solved Win7 to Win8 upgrade..?? in General Support
Would all computers using Win7 be upgradeable to Win8?? I'm thinking about buying a Toshiba all in one touch screen with win7 installed.I read a review that stated the model could not be upgraded because drivers were not compatable. The model is LX835-d3250. This is a recent model release with few...
Is it possible to upgrade the laptop DELL N5110 from Win7 Home Premium SP1 64Bit to Win8 Pro 64Bit? Currently installed on Win7 Home Premium SP1 64Bit, is recommended to perform an upgrade or a clean installation? If I decide to upgrade, will all the files and folders saves? The system...
win7 ultimate to win8 upgrade error in Installation & Setup
hello all, i get this error when i try to upgrade..... Windows 7 Ultimate cannot be upgraded to Windows Developer Preview. You can choose to install a new copy of Windows Developer Preview instead, but this is different from an upgrade, and does not keep your files, settings, and programs. Youll...
