Please help ATI Radeon Mobility x2300 driver problems
  1. #11
    Penn's Forest
    Win8.1 Pro | Win10TP Pro - boot to VHD
    Are there issues with the MS Basic Display Adapter, or is it just bugging you that you can't install the ATI driver?
    Here are some links in this forum that basically say you can use the Vista driver.
    Will Mobility Radeon X2300 work with Windows 8.1
    ATI Mobility Radeon x 2300 graphics driver @ Windows 8.1
    ATI Mobility™ Radeon® X2300 HD - Driver Help
    and ...
    Windows 8 driver for ati mobility radeon x2300
    but ...
    ATI Mobility Radeon X2300 Modded Driver Help - Page 2 - Windows 7 Help Forums
    This seems to be the better solution.
  2. #12
    United States
    Windows 8.1 Pro 64-bit
    There is also a modded driver at Guru3D: HD 2300 Modded Driver of latest 13.5 Beta 2 Release 32/64bit. - Guru3D.com Forums
    EDIT: It would appear that card has come to the end of its life cycle as far as new OS goes. From what I'm reading the basic display driver performs as well as the modded driver.
  3. #13
    Quote Originally Posted by werty View Post
    Although the Mobility Radeon X2300 is part of the HD2000 series its driver support dropped long time ago - it is a DirecX9 graphic card and the Radeon X2400 supports DirectX10. The last driver that supports Radeon X2300 is the legacy Catalyst 10.2 - but it is for desktop cards thus it should be modded to work.
    That was my sneaking suspicion, but I couldn't find anything to confirm it before I had to leave for work.
Page 2 of 2 FirstFirst 12
Hi all... I am having ATI Mobility Radeon X2300 graphic card and it was running fine on my Win 7 but since I installed Win 8.1 pro on my laptop, I couldn't install driver for it... I have tried all solutions stated stated everywhere but couldn't fix it yet, I have even tried the following...
Hi, I own a Fujitsu Siemens Amillo pi2530 and have recently installed the Windows 8.1 x32 OS. It runs with the Ati moblilty Radeon 2300 but i cant find a way to update its driver. I ve tried installing the AMD Catalyst for Windows 7,8 and 8.1 but there was no luck. It seems as if it doesnt locate...
Hi, I am running Mobility Radeon X2300 on ASUS F5V (Windows 8) but I am not sure whether to install Windows 8.1. Is that card compatible with windows 8.1? Has anyone tried to install Windows 8.1 over this card? Thanks :)
I'm looking for a windows 8 64x driver for an ATI MOBILITY RADEON X2300 VIDEO CARD I have a gateway E-295c convertible. I converted FROM Win 7 64x to Win 8 64x- MS generic driver does not provide for dual monitors. I'd like to find a driver or I must restore Win 7. Any help will be...
I am trying to help My Dad which I recently upgraded his Laptop to Windows 8. His Laptop is the Gateway C-140X Convertible Notebook The Specs Doc: Gateway Support - Specifications Support Page: Gateway Support - 1014418R*Gateway C-140X Convertible Notebook
Hi guys, I tried to understand you sticky postings but I am just a normal windows user and this is beyong my knowledge and understanding. Kindly help me out with some hints, wht I need to do: Trouble: Installed the purchased upgrade of Win8 over Win7. Running a HD mobility Radeon HD 5650 GFX....
Playing League of Legends or Diablo 3 on Windows 8 i started to have this kind of bugs: 7031 I tryed to update using the Windows Update driver : "Advanced Micro Devices, Inc. driver update for ATI Mobility Radeon HD 4500 Series (Engineering Sample - WDDM v1.1)" I tried update the latest...
