CrashOverride93
Hello, I'm new here and I never browsed this forum before...
First of all, my english is basic, so if I don't explain very good, I'm very sorry.
OK, what I want to do is the same that a lot of users that have their smartphones (Android OS), is change the original DPI o screen resolution (force a different scale/resolution)
For example if someone know about what I'm trying to say of Android OS is when you want more space avaible on your desktop or the objects/texts/sidebar/icons/etc... looks like smaller than before, you just need to go to this directory (/system) and edit the file (build.prop) and finally locate the line called (ro.sf.lcd_density=xxx) and change the original density number of your screen's device by other smaller; and when you'll restart the device you'll have the same os similar size's desktop of one Note 3 in your SGS3 mini.
I´ll hope I explained good...
So, in resume. I would like to have a 1920x1080 (for example, or smaller I don't know what resolution is correct for my case), from my actual resolution of my laptop that it's 1280x800 pixels.
And for more details:
- Windows 8.1 Pro (x86)
- Resolution 1280x800 (15,4") and 16:10
- Graphic Adapter Intel Graphics Media Accelerator (GMA) 950 (Intel GMA 945 GM)
- Only the original monitor (laptop), not an external monitor
- Computer type
- Laptop
- CPU
- T2050 (x2 cores) - 1.6Ghz (OC up to 2.0Ghz)
- Memory
- 3Gb (DDR2)
- Graphics Card(s)
- Intel GMA 945 GM (256Mb)
