Please can someone help me check compatibility of my parts
    Windows 8.1 Pro 64Bit
    First time builder here , have been researching for quite a long time and want to make sure my part list is good and compatible with each other - PCPartPicker says it is but ive heard bad things where some people have bought 32GB of RAM and only 20/24 is usable
    CPU : Intel 5930k
    Cooler : NZXT Kraken X61 AIO
    Motherboard : ASUS X99-DELUXE/USB 3.1
    RAM : Kingston Savage 32GB (4 x 8GB) DDR4-2400 Memory @ CL12
    GPU : Gigabyte G1 Gaming 980Ti 6GB
    Case : Corsair 750D Airflow Edition
    PSU : EVGA 1000W P2
    *** I already have storage drives and an SSD that i used in my old Acer pre-built tower***
    Any help / insight is greatly appreciated
    windows 8.1
    Here is the support page for your mobo
    https://www.asus.com/us/Motherboards...Desk_Download/
    Look under Memory/Devicesupport for the memory QVL list.
    In the list under ddr-4 2400 there is only 1 Kingston memory module named. Check it, look at the chipnumber.
    But remember such a list is a snapshot of that time, there could be other compatible modules been avaliable on the market later and not added.
    There is also Deviceslist (you can check your (older) HDD and SSD compatibility)
    Under driver check if you need a certain BIOS version, depending on your hardware.
    windows 8.1
    You did not tell for what you gonna use this PC. Is it only gaming?
    Then i would say that 32 gb of ram is overkill, 16 gb is more than enough.
    Quote Originally Posted by lifetec View Post
    Gaming , VMWare , Photoshop , Streaming
    Unless you are doing some major.. major... I mean major. Photoshopping.. that's too much ram..
    and to spend that much money on that.. well, if you got the money and don't care about it being totally changed in 1 year then that's fine.... (have you seen how fast new things are on the way now with computers?)
    Also the next best research you can do is typing in the model name of the ram and then also your motherboard.. so type in google like:
    "ASUS X99-DELUXE kingston savage"
    or
    "asus x99 deluxe Ram kingston problem"
    etc..
    and try to look for forums and boards where people are talking about problems.
    Example:
    "kingston ram doesn't boot up with Asus x99" and stuff like that..
    - your trying to find problems with that ram and your motherboard..
Heya all :) Just wondering if any of you have ever used Flubit to get the parts for your builds - i worked out i could save over 100 on the build by using flubit but i know they use different suppliers to get the product to you so it could be a retailer that has a bad RMA procedure Kind...
I figured I might as well come to the experts here at EightForums for some expert guidance and support on finding parts for my new PC build. I'm working with a budget of $500. I've looked at Newegg and Amazon, trying to find the best deals, but I'm pretty lost as to what grounds to start on. I'd...
So i have a FHD screen IPS :) I changed the dpi and it all looks great for web browsing etc; However file explorer looks HUGE and i cant really use it For apps i just go to compatibility and disable the dpi but how can i achieve this for windows explorer, control panel etc;
This all started when I was trying to connect my Lumia 900 to Zune in Windows 8. I already had Zune installed and it had worked fine before, even connecting my phone worked before. I connected my phone and it wouldn't connect, basic troubleshooting, check drivers, uninstall and update drivers....
Hello, All the text is gone in my Metro menu, in the settings et cetera. When I go to my Desktop, it all works fine. So only the parts that are new in Windows 8 don't work. I can't do a refresh either, because there's no text and I can't see what I'm clicking on. ...
