Need Help. Can’t find script engine “VBScript” for script.
    After reading for a while I got to the conclusion that the problem is related to Kaspersky
    I already tried to re-register
    cd %windir%\system32
    regsvr32 vbscript.dll
    but it didn't work
    This is what CP tells me.
    C:\Users\Chris>reg query HKEY_CLASSES_ROOT\CLSID\{B54F3741-5B07-11cf-A4B0-00AA00
    4A55E8}\InprocServer32
    HKEY_CLASSES_ROOT\CLSID\{B54F3741-5B07-11cf-A4B0-00AA004A55E8}\InprocServer32
    (Default) REG_SZ C:\Program Files (x86)\Kaspersky Lab\Kaspersky Intern
    et Security 2013\x64\scrchpg.dll
    ThreadingModel REG_SZ Both
    OriginalDll REG_SZ C:\Windows\System32\vbscript.dll
    Can anyone help me. I don't know a lot so the simpler your explanation is the better.
    Thanks
    And sorry if any errors ... English isn't my primary language
    Central IL
    Linux Mint 17.2
    Is Kaspersky working or not working? If you are getting a VB Script error, either something was removed in error, or you have the OS locked down too tightly with the A/V software.
    Quote Originally Posted by broe23 View Post
    No, Kaspersky was installed when I made a factory reset and was immediately uninstalled.
    I'm currently using Avast and Ive checked the settings and I don't see any reasons why it should be giving me problems... is there anyway to troubleshoot or any software that can help? if not... what would be my best option?
    Thanks
    Harrisonburg, Va.
    I found this link-
    How To Fix The Error: Canâ
    It might help to run, in admin cmd prompts-
    sfc /scannow
    then,
    then,
    sfc /scannow
    again & restart.
    If you get sfc errors try using the Find function under the Edit tab in the Notepad window of your CBS file of the sfc scan.
    Type in - cannot - & if it finds a .json file it can't fix, ignore it.
    Hope this helps.
Cannot find script file in General Support
This is not really a reply but I can't figure out how to start a new thread so this is what's happening to my computer, (its a custom built ,AMD FX-4100 Quad-Core 3.60GHz, gigabyte GA-78LMT-S2P, win 8.1 pro, 64 bit AVG internet security 2015, internet explorer 11) I had installed win 10 and my...
Hey guys. just finished formating my computer (using the built in windows 8 feature). once it was up and running i uninstalled all the built in stuff lenovo brings with the computer using revo uninstaller. in the procces i also removed all registry and files those programs left.. but now theres...
VB Script not working in General Support
Since this thread is similar to what I want to ask Im writing it about the problem that I have: In windows xp and 7 I did not have this problem but on WINDOWS 8 is a real headache, Right now I have like 20 scripts that use access 2003 that connect to SQL Data in a server, but the first problem is...
I'm looking to remap the vol+, and vol- buttons to run a simple script instead of adjusting the volume on the computer. Anyone have any ideas?
Script behaviours in Software and Apps
Hi all, I have recently purchased a HP Pavilion laptop with Windows8 for carrying out eCourses, but every time I try to launch an eCourse and error message appears and tells me that script behaviours are not enabled, I have enabled them and rebooted the laptop but the same error message keeps...
Script Error in Performance & Maintenance
I have no idea what happened but today I get a " Script Error " on every website and subsequent pages that I enter. Sorry I forgot how to make a copy of what appears on the screen. Thanks
VBS Script is limited in System Security
Using a tutorial yesterday, I couldn't use a lot of my commands I'd normally use in VBS. Security?
