possible way to set default view system wide?
veritasaequi
i was wondering if there is possible way to set default view system wide? the first part of that would be a default (sort by) and (group by). i hate everytime i enter a new folder that its back to that horrible default view, a set it once and forget approach would be so much nicer, i guess the second part of my question would be the same concept but to universally set the line spacing for each folder instead of each time in a new folder. just for clarification im speaking of (name) (type) (date) (and so on). thanks for any helpful insight.
    Custom build
    Lanparty
    12gig ddr3
    Nvidia gt260
    Onboard
    21" oled
    High
    Kingston 128ssd and seagate terabyte
    Black generic
    Liquid
    Wireless
    Wireless
    60meg
    Chr chro chrome
    Deep freeze
    I do work!
Go to Control Panel >Folder Options open the View Tab see if any of the choices/selections there help. If so you click the "apply to all folders" button.
    Win8.1
    HTPC: Custom built
    intel i5-2400
    Gigabyte GA-Z68MX-DS2H
    16GB Corsair DDR3-1600
    on-board HD3000
    On-board
    Samsung 32" LED
    eight HGTS Deskstar NAS, 3TB
    seven WD Red NAS, 3TB
    one Seagate ES.2, 1TB
    one 64GB SSD
    Corsair 750W
    Li-Lian case with SuperMicro hotswap backplane
    Case 4 6" fans, stock CPU cooler
    Two 3-Ware (LSI) model 9650SE-8LPML RAID cards.
The options that im speaking of arent in the folder view tab but thanks for trying to help.
    Custom build
    Lanparty
    12gig ddr3
    Nvidia gt260
    Onboard
    21" oled
    High
    Black generic
    Liquid
    Wireless
    Wireless
    60meg
    Chr chro chrome
    Deep freeze
    I do work!
Then what exactly are you asking about?
The OP gave you the answer to your question.
As for line spacing that is a little different. If you wanting to show detailed information, and wanting it a little larger, that takes just zooming in or changing default font spacing.
    Linux Mint 17.2
    12GB
    AMD Radeon™ HD 7310 Graphics
    Realtek HD
    LCD
    1366 x 768
    Crucial M500 240GB SSD
    Logitech M525
    45/6 - ATT U-Verse
    None needed. It is Linux.
Not quite, you see im actually the op. And if you go back and read the suggestion that was made it simply stated to have a look in folder options "and see" if any of those options would help. Now i can promise you that sort by and group by are not options in folder view. Thanks for sorta trying to help though .
    Custom build
    Lanparty
    12gig ddr3
    Nvidia gt260
    Onboard
    21" oled
    High
    Black generic
    Liquid
    Wireless
    Wireless
    60meg
    Chr chro chrome
    Deep freeze
    I do work!
There is no other way. None of us really know what more you want out of the way Microsoft has set up filters for Explorer. There are other third party explorer tools. Maybe that is what you want.
    Linux Mint 17.2
    12GB
    Realtek HD
    LCD
    1366 x 768
    Logitech M525
    45/6 - ATT U-Verse
Here is what I understand of what Veritasaequi is asking. Let me know if I'm wrong.
When you right-click in a folder or go to the View tab next to File at the top-left of the window, some available options are view (layout), sort by, and group by. (Can provide screenshot if further clarification is required.)
Changing these for the current folder doesn't seem to change them for every other folder. This means every time Veritasaequi opens a new folder, those settings have to be set manually again.
I think Veritasaequi is wondering if there is a way to avoid having to do this manually for every new folder that is opened. Unfortunately, I'm unaware of any method to solve Veritasaequi's problem. I was just hoping to clarify things to help Veritasaequi find an answer to their question.
    Windows 8.1 64-bit
    ASUS X750JB
    Intel® Core™ i7 4700HQ Processor
    DDR3L 1600 MHz SDRAM
    NVIDIA® GeForce® GT 740M with 2GB DDR3 VRAM
    1600 x 900
    2x ST1000LM024 HN-M101MBB
Yes this is correct. I am so happy there is someone in this thread that speaks english. Yes zotar you are exactly correct.
    Custom build
    Lanparty
    12gig ddr3
    Nvidia gt260
    Onboard
    21" oled
    High
    Black generic
    Liquid
    Wireless
    Wireless
    60meg
    Chr chro chrome
    Deep freeze
    I do work!
I messed around with it a little bit and I think I kind of have an answer. It is very similar to what CountryBumkin suggested.
Step 1: Open a folder and set the sort and group settings to your liking.
Step 2: Under the View tab, click on "Options" on the very right and click "Change folder and search options".
Step 3: Under the View tab of Folder Options, click the "Apply to Folders" button.
Doing this in C:\ changed just about every folder. For some reason, it seems it will have to be repeated for some folders like Documents, Pictures, Videos, and Downloads. At least I seemed to have to.
It doesn't seem to be perfect, but I hope it helps cut down the number of times you have to change the settings manually.
    Windows 8.1 64-bit
    ASUS X750JB
    1600 x 900
Once again thanks zotar. This is surely along the sorts of which i was serking. Your correct it not perfect but its a good start. Thank you good or your help. I keep thinking there is something that can be changed in the registry yo set these options system wide i just cant find any sort of info in that area on the web yet.
    Custom build
    Lanparty
    12gig ddr3
    Nvidia gt260
    Onboard
    21" oled
    High
    Black generic
    Liquid
    Wireless
    Wireless
    60meg
    Chr chro chrome
    Deep freeze
    I do work!
