Solved Clicking sound when using CTRL+key or SHIFT+key
kingneil
In Windows 8, I am hearing a clicking sound whenever I use either CTRL+key or SHIFT+key
So, when I'm doing shortcuts, or capitalising letters..... it just makes an annoying clicking sound.
How do I turn this off?
OK. Don't worry.
This occurs when you have the on-screen keyboard switch on.
If you switch off the on-screen keyboard, it no longer happens.
