Cannot lower Critical Battery Level in Power Options
  1. #11
    Thanks for the suggestions adamf. The key numbers correspond exactly with the ones in Windows 8.1 on my machine. It appears that changing the registry entries is the same as using powercfg from the command prompt.
    I edited the appropriate registry keys and it seems that the change is purely cosmetic - I can verify that when I edit the registry key to 3%, the setting in Power Options says 3% also. The strange thing is that if I use Power Options to try to change it to anything from 0% to 6%, it now jumps back automatically to 3% (because that is what the registry key is set to). However, even more strange is that I can use Power Options to change it to anything from 7% and above (and the registry value updates with it).
    I say that the change is purely cosmetic because I tested it out by running the laptop after changing the registry entry to 3%. I couldn't even get the laptop to run down that low because the blasted thing still insisted on shutting down at 7%, despite the registry saying otherwise!!!
    I have to mention that I did take ownership of the registry key as suggested. I tried numerous combinations of owners/permission levels (System/Administrators/User) and it's still the same story.
    It appears HP has somehow locked down this 7% limit somewhere. I have faith that if HP can lock it down, there must be a way to unlock it.
    I haven't given up on HP support yet. I just need to wait until Tuesday now for a response from them (something to do with what happened to some guy more than 2 millennia ago....but I digress
    Thinking I might need to take drastic action by formatting the entire thing and installing a different copy of Windows.
    Happy Easter folks
  2. #12
    Central IL
    Linux Mint 17.2
    Quote Originally Posted by segap21 View Post
    That's rather confusing. I mean no disrespect but I thought this was a Windows forum to discuss general support issues relating to Windows. As I mentioned before, I just want to set the critical battery level to something more reasonable than 7%. I think that should be achievable since adamf can do exactly that.
    Hoping that someone can shed some more light on this.
    Just because a person does not use Windows on their computer, does not mean they do not know a thing or two. I just opted to not run Windows 8, just like a few thousand plus others.
  3. #13
    Quote Originally Posted by broe23 View Post
    Exactly, and this is beside the point.
    What is more relevant is do you know how to fix the issue at hand?
    All you have suggested to me so far is that it is unwise to run the battery completely flat (which I acknowledged already) and that the setting is coded into Windows to not allow anything lower (which turns out not to be entirely correct).
    I'm open to any further suggestions on how to fix this so I can choose my own Critical Battery Level in Windows, and not be dictated by what HP thinks.
  4. #14
    Central IL
    Linux Mint 17.2
    As has already been stated over and over, you cannot. It is coded into the AHCI driver to not allow you to completely drain the battery, so it becomes a door stop after a couple of times running it all of the way down.
  5. #15
    Windows 10 Pro Prieview x64
    You could try that but I don't know if it would work. My problem is I run Windows on a MacBook Pro which is one of the models that your original link said worked so it is difficult for me to test (well impossible really).
    Rather randomly I was reading a few weeks ago about hacking the firmware on MacBook batteries (resetting maximum and minimum voltage levels, changing cycle counts and so on) to see if you could make the battery catch on fire by flashing the firmware. The answer was theoretically yes but in practice it was too complicated.
    Certainly the chip in the battery does a lot of work and can override whatever you may choose to do to it from outside so I don't know if replacing your OS would help. It would not work on a MacBook battery - on a HP battery I'm beyond clueless.
    You could try changing - do a backup and then just install Windows 10 or something and see if it helps. It's free so why not if you have the time.
    Maybe someone else (a helpful person ideally) will see if they can change their critical discharge limit or not - seems you've had enough opinions about whether you should
  6. #16
    Helpful comment
  7. #17
    Central IL
    Linux Mint 17.2
    Even in Mac OS & Linux. You can only go to 1%. It is done so a person does not burn out the LiON salts in the battery.
  8. #18
    I do not follow how AHCI drivers affect the battery settings. I thought AHCI drivers were to do with how data is exchanged between system memory and attached storage devices?
  9. #19
    Quote Originally Posted by adamf View Post
    Yeah, looks like I will give this a go if I can't find an alternative solution soon.
    In the meantime, calling all Windows 8.1 users who just happen to be reading this post but may not have a solution - could you please have a look at your Power Options and see if you can change the Critical Battery Level downwards. You do not have to test it further by running your laptop till it dies; if you could just see if the setting will stick and report back it will be much appreciated.
  10. #20
    Life is hard with all these acronymes How about you try ACPI? Windows Dev Centre Hardware
    Quote Originally Posted by Microsoft
    Design capacity of Low Indicates the critical battery level at which Windows must immediately shut down or hibernate before the system powers off. Must be set to a value between 0 and 5 percent of the battery design capacity
    Now if you are saying HP batteries are not conforming to Microsoft specifications there isn't really much more to do than take it up with them as
    Windows platforms are expected to expose their battery devices and AC adapters in firmware through ACPI by using standardized control method interfaces, as described in the ACPI 5.0 specification.
I went into my power options to change some of the advanced settings and most of them are missing? I am on windows 8.1 with a week old Surface Pro 3. I want to say I read somewhere that hyper-v can cause options to be missing, but I honestly don't even know what that is and I don't have it...
Recently I noticed a game that I had been playing had started to stutter and slowdown more than usual, the performance issues were to be expected as the games engine is notorious for being poorly optimized, however these occurrences were fairly rare in comparison to the issues i'm experiencing now....
Giving specific applications administrator level power in User Accounts and Family Safety
Hi, I have a normal standard account on my Win8 and have the admin level password. On the normal account, steam can start and run games easily. However, Origin (by EA) does not. Every time I try to log into origin, it wants the administrator level password, which is annoying. I tried...
Solved A Lower Level "Start" Screen in General Support
Hi All, I am new to Windows 8, which I am using with a non-touch screen so I am dependent on the mouse for controlling actions. The Start Screen has enough items on it to require me to scroll across to see them all, even when grouped. I would like to be able to have a second (lower level)...
About 1-2 weeks ago, I had 15GB of space left on my SSD that is solely committed to OS and drivers. Today, I have 2.9GB left. I have downloaded nothing, and I have changed nothing. What is going on? Any programs to help me take a closer look at why my SSD space is disappearing? I've had this OS for...
Hi, I hope someone can help. I have an Dell Inspiron 1545 laptop that was originally Vista but now is running 8 pro. The problem I have is that since I upgraded to Windows 8 Pro, I no longer receive an on-screen message warning of low battery level. I however still have the battery level...
