USB CABLE, Monitor Input, PC input?
    What can be done with USB Cable regarding PC? Is it worth it?
    I use a Dual monitor cabe, one end plugs into The Display shared Vga Connection. The other 2 allow me to have up to a total of 3 Displays. Is there products that allow more than the standard 2 outputs? Example 4?
    Thank you
    Quote Originally Posted by mmdlshooter View Post
    Thank you
    USB, even USB3 was never meant for transferring large amount of data needed for HD video, too much conversion has to be made. Laptops are limited by number and type of outputs but desktops can accommodate multiple video cards and even basic cards with Display port that use power of existing GPUs to provide video signal to more monitors or TVs.
    Tyvvm
hello all. I have problem with changing input language. I have tablet running windows 8.1 with bing. In the PC settings, Time and language, Region and language i have 3 languages listed. But i can't switch between languages in touch keyboard. I only can use english. why? anyone can help?...
Can't change input language. in General Support
Using Windows 8.1. I have English and Japanese input languages added, and both are listed as options in the language toolbar, but it is impossible to select anything but English. Windows+Space allows me to navigate to Japanese, but releasing the keys or pressing Enter does nothing. The Left...
Treat mouse input as touch input in Drivers & Hardware
Hi, Happy new user of my first Windows 8 device (Dell XPS 12 i7 running Windows 8.1 Pro). I like the touch input when it is flat in tablet mode, but when I plug a USB mouse into it when I am at my desk, I want the mouse inputs to be treated exactly like finger inputs on the touch screen. For...
Hi I have the following input languages in the Language settings in the control panel: - Arabic - English (United Kingdom) - Turkish But when I switch between the language I have 5 input languages where the English and the Arabic are doubled!! Check the attached image : 30470
So my Laptop does accept HDMI as Input to. But i dont know about any program, that can watch what is being put in. Does someone know one?
US ENG Input Language Changing in General Support
Hi everyone. I have searched everywhere for a solution to my problem and I still haven't found one. I have a Sony VAIO VPCSE and I have installed Windows 8 Professional. My region, language, input methods etc are set to English(Ireland) The Problem When I turn on my laptop, there is the...
Solved How to add new input language in General Support
How to add new keyboard input language ? I have one language, but i want to add english language. I go to control panel, language, add a language, then i select english, and then just blank window appears... : 10693 Or i go to language, then select for current language options, add an input...
