Solved Problem with Radio Shortcut Addresses
NourinE
Morocco
Hello!
I have a problem with radio shortcuts that I created a few months ago. When I double click a shortcut addresses to listen to as usual the error message below appears.
I tried to recreate them again, but always the same result.
the only way I can play them is copying the addresses and opening Windows Media Player => File => Open URL, I then pasting the addresses.
I can't figure out why the shortcut links of the radios don't work any more !
    Windows 8.1 64bit (6,3 Build 9600)
    Sony VAIO SVE1512A4E
    Intel(R) Pentium(R) CPU B980 @2.40GHz 2.40GHz
    4,00 Go
    Intel Corporation Intel HD Graphics
    Intel Corporation 7 Series/C210 Series Chipset Family High Definition Audio Controller
    Monitor Plug-and-Play générique
    1366x768
    Harddrive ST640LM001HN-M640MBB from 596.17 GB SATA II
    Avast! INTERNET SECURITY
any suggestions please?
    4,00 Go
    1366x768
I'm not sure what a radio shortcut is - Radio is most likely a poorly translated word.
Is there another word you could use to describe the shortcut?
Is it possibly a play list?
    Win8.1 Pro | Win10TP Pro - boot to VHD
    HP Pavilion dv6-c610us
    AMD VISION A6-3420M Quad-Core (2.4GHz/1.5GHz)
    HP
    6GB DDR3 SDRAM (2 DIMM)
    AMD Radeon HD 6520G Discrete-Class Graphics
    HP 2072a (20" LED)
    1600 x 900
    Hitachi 640GB (5400 RPM)
    Seagate 2 TB external
    WD 500 GB external
    Logitech K520 (wireless bundle)
    Logitech M310 (wireless bundle)
    IE 11 (default) & Pale Moon
    HP product specs:
    http://support.hp.com/us-en/product/HP-Pavilion-dv6-6c00-Entertainment-Notebook-PC-series/5191856/model/5218495/document/c03138553/
Thanks for your reply.
what I mean is the Shortcut that you can create by right-clicking in the desktop => New...in a step you can copy and paste a link of a radio like 'mms:cnn.com.livestream'. that I called Radio Shortcut Link or Address.
I hope the translation is better now.
    4,00 Go
    1366x768
    Gateway
    AMD K140
    Cores 2
    Threads 2
    Name AMD K140
    Package Socket FT1 BGA
    Technology 40nm
    Family F
    Extended Family 14
    Model 2
    Extended Model 2
    Stepping 0
    Revision ON-C0
    Instruction
    Opera 24.0
    Avast Internet Security
no, this is an example : mms://50.22.223.13/m....
    4,00 Go
    1366x768
Could you post a link to the radio station.
What you posted here does not look right. :(
    Gateway
    AMD K140
    Cores 2
    Threads 2
    Name AMD K140
    Technology 40nm
    Family F
    Extended Family 14
    Model 2
    Extended Model 2
    Stepping 0
    Revision ON-C0
    Instruction
    Opera 24.0
mms://a1477.l3760635476.c37606.n.lm.akamaistream.net/D/1477/37606/v0001/reflector:35476
    4,00 Go
    1366x768
I tried it & it won't play.
If you will post the url of the radio station I might be able to help you.
Like this---
WMRA
http://wmra.org/
    Gateway
    AMD K140
    Cores 2
    Threads 2
    Name AMD K140
    Technology 40nm
    Family F
    Extended Family 14
    Model 2
    Extended Model 2
    Stepping 0
    Revision ON-C0
    Instruction
    Opera 24.0
it's for CNN news channel
here others :
mms://50.22.223.13/s_gmd
mms://50.22.223.13/afs
mms://50.22.223.13/frs_a
    4,00 Go
    1366x768
none of them work any more for me
    4,00 Go
    1366x768
    Gateway
    AMD K140
    Cores 2
    Threads 2
    Name AMD K140
    Technology 40nm
    Family F
    Extended Family 14
    Model 2
    Extended Model 2
    Stepping 0
    Revision ON-C0
    Instruction
    Opera 24.0
cnn, I was just listening to the new on it,it is a radio.
    4,00 Go
    1366x768
Take a screenshot of the page & point out EXACTLY what you click on to get the radio.
Otherwise someone else will have to step in & offer help.
A picture---
    Gateway
    AMD K140
    Cores 2
    Threads 2
    Name AMD K140
    Technology 40nm
    Family F
    Extended Family 14
    Model 2
    Extended Model 2
    Stepping 0
    Revision ON-C0
    Instruction
    Opera 24.0
here is where I click on to listen to the radio
    4,00 Go
    1366x768
Thanks, your translation was fine. The problem was my understanding ;)
I tried to open the stream (from one of your posts) in VLC and I'm not getting anything either.
I'll play around with it and try a few other streams to make sure it's not VLC, my connection, or some other technical bottleneck.
But at first glance, it looks as though those streams(I only tested one) have been taken down or the stream address has changed.
Are any streams working for you?
Bill
    HP
    HP 2072a (20" LED)
    1600 x 900
    WD 500 GB external
    HP product specs:
    4,00 Go
    1366x768
Thanks, this seems to be either a link (shortcut) issue or a filetype association specific to the mms protocol issue.
I tried creating a shortcut using only the mms address of one of your working addresses, but Windows didn't like it. I've never tried this before, so it's obvious that's not the right way to do it.
Do other shortcuts on your desktop work? You can test with a simple shortcut to your temporary files is you don't have one handy.
use environment variable defined for \appdata\loacal\temp as the target location for the shortcut
%TEMP%
Then try the Temp shortcut you just created
If that works (or any other shortcut you already had works), then I'll need a little help creating one for the mms protocol.
Please post the target field of any of the Radio shortcuts and I'll try to recreate what is happening on your machine.
It's probably something like
Target: [ C:\Program Files\...\VLC.exe mms....]
(best I can do to simulate the field box)
Since you already have some, let me know what one looks like.
You can just grab the text in the Target filed or post a screenshot of the shortcut properties
Thanks
    HP
    HP 2072a (20" LED)
    1600 x 900
    WD 500 GB external
    HP product specs:
Hmmm, I seem to be having technical difficultities.
And you've already told me what the target location is - sorry about that.
I tried using VLC and hit a firewall issue - that's not the issue on your side though since you can listen if you paste the address directly into 'Open URL'.
I tried to emulate the issue using VLC but I know you are using Media Player.
I might not be best suited to help due to my configurations, but I'll keep looking into it.
This has always interested me and I can play some streams. I often find it difficult even when I plug the address into the Network URL field (VLC's equivalent field to WMP Open URL.
I might have to reinstall WMP to test.
Bill
    HP
    HP 2072a (20" LED)
    1600 x 900
    WD 500 GB external
    HP product specs:
I had to resort to the command line to get VLC to play one of the mms addresses, it took a while to load, but eventually did play.
I modified a bookmark in Ineternet explorer, so now I have a Internet shortcut that has a mms target location.
Another brick wall, VLC is not registered to support the mms protocol. I'll fix that, but the easy 'associate a filetype or protocol" in default progams isn't playing nice.
None of this has anything to do with your side, only my trying to emulate the issue on my side.
There is one question that comes to mind:
how did you create the shortcut? New -> shortcut?
Try what I did ... bookmark your thread (this page) and name it mms-a
then open bookmarks,
right click the bookmark mms-a (the one you just created) and
select properties
paste
mms://50.22.223.13/afs​
into the URL field, then
press OK
Go back to bookmarks and double click the bookmark mms-a
If that works, navigate to the Favorites folder under your user ID and drag the bookmark mms-a to your desktop.
Try the shortcut from your desktop. Why? to test it from there (your thread mentions desktop - but if it works in your bookmarks folder it should work anywhere)
    HP
    HP 2072a (20" LED)
    1600 x 900
    WD 500 GB external
    HP product specs:
