need wireless adapter power options
    Could you please provide instructions for adding the options related to the wireless adapter?
    Hello beatcal, and welcome to Eight Forums.
    I write up a tutorial for this later tonight, and will post back with a link to it when ready.
    United States
    Windows 8.1 Pro 64-bit
    Shawn, you are the man! Or is it alien?
    Quote Originally Posted by popeye View Post
    I'm a hybrid.
    Brinks address is Area 51.......
    Quote Originally Posted by Brink View Post
    Awesome, thanks very much.
    You're most welcome.
I installed Win 8 Pro upgrade 2 days ago on my laptop. At first, my wireless adapter was working fine as the Win 8 install process checked for updates before beginning. Update seemed to work fine but after completion I descovered my wireless adapter no longer worked. I need help getting my...
I went into my power options to change some of the advanced settings and most of them are missing? I am on windows 8.1 with a week old Surface Pro 3. I want to say I read somewhere that hyper-v can cause options to be missing, but I honestly don't even know what that is and I don't have it...
How to Add or Remove Wireless Adapter Settings "Power Saving Mode" in Windows The "Power Saving Mode" option under the Wireless Adapter Settings section is used to configure how much power you want to save when using your wireless network card. There are four types of power saving modes...
8.1 - Wireless Adapter shuts off in Network & Sharing
Hi, After a while when i'm browsing the web etc, my wireless connection goes to Limited and there are no other wireless networks available (when there should be 10+ networks). When i disconnect that limited connection, there are suddenly no networks found and my wireless adapter disables...
wireless adapter in Network & Sharing
which wireless adapter is cheap and compatible to use on a windows 8 desktop? i have recently purchased a new windows 8 desktop but as i don't know much about desktops i thought they had built in wireless like a laptop, my computer is in my bedroom and my modem is downstairs, this is why i need...
Anyone having problems connecting wireless? I have a Netgear WNA 1100 wireless adapter and when I use the push n play feature to link my router & computer it crashes my machine with a irq error.
