Help - weird problem
    I had a 2TB WD Black HD that was developing bad sectors, so I decided to replace it with a WD Velociraptor 1 TB HD. Everything seemed fine., though I didn't do a lot on the computer so I can't say for sure. Power outage the next night. Starting the next day, the computer boots up and shuts down fine, but is slow at opening up applications.
    I tried to uninstall one software program, and couldn't. I get error message 1606, saying it can't access the Public Shared Pictures location on my external My Cloud device). First, the software was never installed on the external device. Then I discovered the IP address for the My Cloud device is now different from the address that appears when I try to uninstall.
    I tried a system restore - it doesn't work and gives me the 0X800700b7 error message. I tried sfc/scannow as well a registry fix I found while googling for a solution. Didn't work.
    I also tried unplugging the new HDD, which also did nothing.
    Any ideas?
    The most basic idea, in the most basic term......
    Don't ever buy a WD drive again.
    That piece of wisdom comes from my own experiences over 34 years, being in the computer repair business.
    Sorry if that flies in the face of anyone's personal experience with a few WD drives.
    Good Luck!
    Quote Originally Posted by TechnoMage View Post
    Good Luck!
    I have to agree, while not going through a lot of computers the last two I set up with WD Blacks I guess I went though 5 or 6 to get 3 that actual worked. Warranty's are good and for spinners how have any better ones that goodness for SSD's
    PLEASE do NOT hijack this issue into a WD bashing. I don't find that to be in the least bit helpful nor particularly relevant. I've had a number of WD and Seagate drives in particular, as well as other brands - for a whole lot of years as well. Occasionally one goes bad, but generally I have not had issues. Certainly never anything like this.
    More detail. It appears to be an issue with Adobe software. All other software I can uninstall and then reinstall without any issues. I found a fix that allowed me to uninstall Adobe Reader. However, when I tried to reinstall it, I got the same error message 1606, saying it can't access the Public Shared Pictures location on my external My Cloud device) (again, with the wrong IP address). For some reason, it wants to install Adobe software to the network rather than my C drive. Any ideas on how to fix this?
    Is it possible when the computer is on that there is an Adobe service running in the background that is continually looking for the My Cloud network drive (a the wrong IP) and that is slowing everything down?
    Hi Salamander,
    From your post I make a conclusion that is more a software related issue rather than WD My Cloud hard drive related one.
    This error message usually is shown when the installer can't resolve a path during the installation of Adobe. Sometimes this type of error is generated when you attempt to access the installation path of Microsoft Office during the installation of the PDFMaker components. Restoring this path or reinstalling Office typically resolves these issues.
    You could try these steps:
    - Close all open applications.
    - Copy all documents you want to keep from the Office folder to another folder.
    - On Control Panel click Add Or Remove Programs select Microsoft Office and click Remove.
    - Restart your computer.
    - Install Acrobat
    - Reinstall Microsoft Office.
    Another thing you could try is "Microsoft Fix it" wizard to update Windows registry.
    Hope this helps.
    KY_WD
    I finally got it fixed - it's been just over 24 hours without any issues.
    I got a number of suggestions on this and several other forums, none of which worked when I tried them, though one of them turned out to be where I needed to be looking.
    The suggestion to go to the microsoft website (You receive an "Error 1606" error message when you try to install or remove a Microsoft program) was the most helpful in the end. Mr. Fix-it wouldn't work on Windows 8.1, so I then followed the directions to do it manually. It indicated this error issue may occur if there is an incorrect setting in one of the following registry subkeys:
    •HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\User Shell Folders
    •HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Explorer\User Shell Folders
    I made the mistake of assuming it was just referring to software that has been installed, specifically Microsoft products. I went to those registry subkeys, and found several entries referring to older versions of Office. I deleted them. When that didn't resolve it, I went on looking for other solutions.
    Given the installation/un-installation issues were only with Adobe software, I assumed that Adobe was a possible culprit. I tried a number of suggestions regarding Adobe. Nothing worked. As I noted earlier, I tried removing the new HDD to see if that was the issue. Nothing.
    I was getting ready to do a reinstall when I started thinking again about the text of the error message, saying it can't access the Public Shared Pictures location on my external My Cloud device, and showing the wrong IP address. I went back to the registry subkeys noted above, and looked for registry entries NOT about Microsoft, and NOT about Adobe, but instead ones that might reference the My Pictures folder. And there I found the problem. In both registry subkeys, there was one entry that referenced my pictures, and the text of the subkey contained the wrong IP address. I changed the IP address to the correct one, re-booted, and just like that the issue was fixed!!!!!
    A little more time thinking it through would have saved me a whole lot of time searching for solutions. Live and learn.
    Thanks to everyone who offered suggestions!!! I hope this helps someone else!
Weird USB Problem in Drivers & Hardware
Heya, I've got weird USB problems, and can't seem to work out what's wrong. I'm using Windows 8 x64, all updated, which had been working without problem for about 8 months now. I noticed my internel card reader drives (9 pin USB header) kept disappearing and reappearing quickly, in both My...
Weird Problem in Network & Sharing
First off I have 5 Windows computers in my house. 3 with 8.1, and 2 with Windows 7. I have an ASUS RT-AC66U wireless router that supports A, B, G, N, & AC. My problem is with my HP 7520 All-In-One printer hooked up wirelessly. With all the pc's off and the printer on in standby mode, I can start...
I have this weird problem in General Support
Hi I have this really weird problem. I recently upgraded my laptop to Windows 8. Everything went fine and there was no problem whatsoever. But recently, all the buttons inside the Metro (or, Modern) UI have disappeared. Either it shows only the outside ring with the insides blank, or boxes(like...
Solved Weird printer problem in Drivers & Hardware
I have a Canon MP990 All-in-One which has been working perfectly from when I installed the Canon drivers on my new home build W8 64bitpc a few weeks ago. This included successfully printing pdf files via the W8 Reader App. I set up the MP990 to always show a print preview before printing. All...
Solved Weird Problem in General Support
I'm having an issue I've never seen before. It seems to happen maybe a couple times a day (haven't paid that close attention yet). I'll be sitting there and notice the hard drive activity light is on steady and won't even blink. I can work on the system normally though. However when I try to...
Weird Weird Problem! in Network & Sharing
I have the strangest problem with my internet since updating to W8. My internet works absolutely fine all day, up until later in the day (not sure what time exactly this happens) but it stops working! It says it is connected but it simple can't find a network. I am connected via LAN to an...
Running W8 Pro x64 RTM (from Technet) I'm having a weird problem that I can't seem to pin down the cause. Whenever I run Task Scheduler, Print Management, or Event viewer and then exit them, a folder is created on my desktop called 'Administrative Tools' Clicking on this folder opens up...
