Need some help with a dimming problem
    Ok I was using the consumer preview build 8250 for about 2 weeks with two monitors my main one being an actual lcd monitor connected by a DVI connector and the other being my TV connected with HDMI. and I noticed no dimming issues what so ever. recently I have added a second lcd to my computer and removed my TV from the mix I now use my hdmi cable in my ASUS monitor that I was using previously but now I am having issues with the screen "randomly" dimming I say randomly loosely because it does it at certain times Most of the time.. when looking thru the steam store once I scroll down thru a list about a fifth of the way the screen will dim and stay dim till I scroll back up same goes with web pages with videos also I noticed it happening While playing mass effect 3 multiplayer for you guys that have played the game, when I would look towards a enemy and the orange box would highlight the enemy my screen would dim and remain dim until I killed it or looked away... this is really becoming an severe annoyance and if anyone knows a remedy I would greatly appreciate it.. let me know if you need specs.. I have tried several different drivers with my video card and its still same results.. im hoping its just a setting I have over looked.
    Oh and a quick add too.. this is only happening on my main monitor that is connected to my PC using the hdmi cable
    Hi,
    Type services.msc in the start page and press enter. Disable the Sensor Monitoring Service and stop it too. See how it goes.
    Tried the Disable sensor montoring, It was already off the diming is also happening when windows popup anyone got any other ideas?
    Belgium
    Windows 8 CP x64
    I had this problem on my Inspiron 1564, a BIOS update fixed it. Another thing that can fix it is locking the brightness of the screen in the BIOS (or turning the sensor OFF there). However I don't know if your BIOS support such things.
    ~Aeny
    Im using a desktop PC so i don't have any options like that.. ive also recent noticed that the windows that pop up and make my monitor dim if i move them away from the center the screen undims
    Anyone else got any great ideas.. its starting to get really old..
    Did you update your motherboard bios yet?
    Did you run a Windows Update to see if it installs a monitor driver? If the monitor is generic in the device manager, look into visiting the monitor's hardware manufacturer to get a driver to install.
    Did you check the monitor properties to be sure that it is running at a resolution and also frequency intended by the manufacturer?
    Ya man, the more I think about this, it sounds like HDCP kicking in and/or going wrong.
    The stuff in my last post should set it well. I am guessing you don't have a monitor driver installed for it yet.
    High-bandwidth Digital Content Protection - Wikipedia, the free encyclopedia
    Portsmouth Hants
    I didn't mention this in the thread I had in the Crashes and... section, but while there was a problem brewing, as well as random freezes, the screen brightness fell, and became better when the problem was resolved.
I've seen a lot of questions regarding this subject, and a lot of stupid answers that lead nowhere but to the end of the thread without any solutions, any progress or real help given. So here, as I try and contain my irritation as the window continues to constantly dim as I type this requiring me...
Solved Screen Constantly Dimming in General Support
I am running 64 bit Windows 8 on a VAIO touchscreen laptop. Yesterday, my screen started randomly dimming itself. When I went to change the brightness back up, as I held down the button it kept jumping back to a low brightness. When I tried setting my brightness in the power options, it would save...
Dimming issue in General Support
So my computer is dimming like every few seconds, how do I fix it?
Dimming and Battery Life in Drivers & Hardware
I just upgraded to windows 8 from 7 on my HP Envy15 with an i7 but i had a few things it said i need to re-install after i upgrade, HP Battery Management was one of them, which i though i re installed but im not sure if it worked because it still tried telling me i needed to update it after i...
I can not dim or brighten my moniter, not with f2 f3 not through power management, not through mobility center, nothing, my screen is stuck at one brightness, i hve an hp envy 15, please please help, this is killing my battery life and is relly getting on my nerves
Solved Display randomly dimming during use in Performance & Maintenance
Hi Guys, Im new to these forums so bare with me. I have upgraded to windows 8 pro (no dodgy hacks) it is the full version and is 32 bit. Once battling with System_Thread and Unreadable_memory and any bsod you can think of I got it working BUT now for some weird reason the screen randomly dims...
Strange problem I've been experiencing with Windows 8 (and ONLY Windows 8) for a few weeks now. When I am on the desktop and I hit the Windows key to go to metro to search or do anything, the screen will get noticeably darker and proceed to "fade in" to full brightness. This also seems to...
