Options Missing from Power Options Advanced Settings
  1. #21
    You're most welcome.
  2. #22
    Windows 8.1 (HOME not Pro) 64bit
    what is this all about? why would options not be in the Advanced power settings? who would take those out and why?? Now i'm wondering what's missing from mine???
    I assume after a fresh install of windows 8.1 there is no need to make sure i have all my advanced power options right?
    I've never heard of someone needing to add those options in again.. what crap is this? what program would remove those and why can you even remove them??
    so odd.
  3. #23
    Hello bassfacer,
    Some power options are only available based on your system specs.
    Some times items may get removed for whatever reason (program or user error), and this allows them to add them back.
    Other times, users may wish to remove items to make it harder to change them by mistake or by other users.
  4. #24
    Windows 8.1 Surface Pro 3 i5
    Hello, I found this guide really helpful thanks for sharing!! I have one question, could you add the Gpu settings? I have a SP3 i5 Windows 8.1.
    Thanks in advance!!
  5. #25
    Quote Originally Posted by Blink View Post
    Thanks in advance!!
    Hello Blink, and welcome to Eight Forums.
    Which specific GPU power options are you referring to?
  6. #26
    GPU Settings
    Quote Originally Posted by Brink View Post
    Thanks in advance!!
    Thanks!
    I mean the Intel(R) Graphics Settings, is that possible? I want this because I use this SP3 for light games sometimes and I don't like to enable the High performance mode by disabling connected stand by because I loose the sleep functionality and some other stuff. So if I could add those GPU settings + the processors settings (that I already added) above that would be great!
  7. #27
    Sorry, but no. That's a part of the Intel HD graphics driver software instead.
    Latest Intel HD Graphics Driver for Windows 8
  8. #28
    Gpu Settings
    I downloaded intel drivers instead and was able to access intel gpu settings and set it to high perfomance on display and battery life so i guess is the same.
    Thanks anyways!
  9. #29
    Great news.
Page 3 of 3 FirstFirst 123
Hello to all, Wanted to confirm something I recently had a problem with on W7. It was fixed but I didn't get an explanation that I could remember. I have an Athlon X2 processor. In msconfig > boot tab > Advanced Options - there is a box the has a checkmark and a box that show the number of...
Hi, The way I know my desktop PC has gone to sleep is that the blue light around the power button flashes (instead of being on all the time). I'm playing around with some settings right now to find out exactly what is pulling it out of its sleep. I realized that if I go to Power Options and...
How to Add or Remove Wireless Adapter Settings "Power Saving Mode" in Windows The "Power Saving Mode" option under the Wireless Adapter Settings section is used to configure how much power you want to save when using your wireless network card. There are four types of power saving modes...
Hi all! My first post and visit here so please be kind :p I have problems installing a legacy driver, and one proposed solution given was the following: 1. Windows Key + R 2. Enter shutdown.exe /r /o /f /t 00 3. Click the "OK" button 4. System will restart to a "Choose an option" screen...
I note a zillion angry threads to MS re: the Power Mgmt issues in 8's. anyone know workarounds? I've been working with 8.1 on a notebook, where all devices luckily are installed right and functioning right, until I go trying to make it play nice as a HTPC system... USB-attached...
I am trying to Boot from a USB Pen Drive on my Asus VivoTab running 8.1. There is no keyboard available in Trouble Shoot/Advanced Options UEFI Firmware Settings & Startup Settings. Screen or Asus Bluetooth keyboard. BTW the 8.1 update went well. All my Desktop apps were preserved as well as...
I recently got my lenovo g500. (recently like 5 days ago) and every so often the power options disappear. I can click the power but nothing shows up to shut down, restart, etc. Also during this time I can go to the start screen but cant click any of the apps, not even the desktop, but I can Alt tab...
