Options Missing from Power Options Advanced Settings
  1. #11
    windows 8.1
  2. #12
    Hello BD007, and welcome to Eight Forums.
    I'll add it to my list to do tomorrow, and will post back with a link to it when finished.
  3. #13
  4. #14
    windows 8.1
    Worked perfect! Thanks Brink!
  5. #15
    You're most welcome.
  6. #16
    Win 8.1
    Brink, you're a champ, really, made my day!
    I wonder if you have an idea how I could get back the battery time estimation when I mouse-over the battery icon in the notification area?! My Surface Pro 1 told me something like " 66% 2h 35 min", the Surface Pro 3 only "66%". Ho could they kill such a feature??
    Ralph.
  7. #17
    Hello Ralph, and welcome to Eight Forums.
    Yeah, I've never figured out what made that different, and why/when it sometimes only shows a percentage instead of both.
  8. #18
    window 8.1
  9. #19
    Quote Originally Posted by Inuyasha1987 View Post
    Hello Inuyasha, and welcome to Eight Forums.
    Here's a tutorial below to remove "Internet Explorer" from Power Options.
    https://www.tenforums.com/tutorials/3...r-windows.html
    It would be pointless to remove "Power buttons and lid" in the advanced settings though since it would still be available in the "Choose what the power button does" and "Choose what closing the lid does" links in Power Options.
    Hope this helps,
  10. #20
    window 8.1
    Quote Originally Posted by Brink View Post
    Hope this helps,
    Thank you so much, Shawn . Hope all best to you
Hello to all, Wanted to confirm something I recently had a problem with on W7. It was fixed but I didn't get an explanation that I could remember. I have an Athlon X2 processor. In msconfig > boot tab > Advanced Options - there is a box the has a checkmark and a box that show the number of...
Hi, The way I know my desktop PC has gone to sleep is that the blue light around the power button flashes (instead of being on all the time). I'm playing around with some settings right now to find out exactly what is pulling it out of its sleep. I realized that if I go to Power Options and...
How to Add or Remove Wireless Adapter Settings "Power Saving Mode" in Windows The "Power Saving Mode" option under the Wireless Adapter Settings section is used to configure how much power you want to save when using your wireless network card. There are four types of power saving modes...
Hi all! My first post and visit here so please be kind :p I have problems installing a legacy driver, and one proposed solution given was the following: 1. Windows Key + R 2. Enter shutdown.exe /r /o /f /t 00 3. Click the "OK" button 4. System will restart to a "Choose an option" screen...
I note a zillion angry threads to MS re: the Power Mgmt issues in 8's. anyone know workarounds? I've been working with 8.1 on a notebook, where all devices luckily are installed right and functioning right, until I go trying to make it play nice as a HTPC system... USB-attached...
I am trying to Boot from a USB Pen Drive on my Asus VivoTab running 8.1. There is no keyboard available in Trouble Shoot/Advanced Options UEFI Firmware Settings & Startup Settings. Screen or Asus Bluetooth keyboard. BTW the 8.1 update went well. All my Desktop apps were preserved as well as...
I recently got my lenovo g500. (recently like 5 days ago) and every so often the power options disappear. I can click the power but nothing shows up to shut down, restart, etc. Also during this time I can go to the start screen but cant click any of the apps, not even the desktop, but I can Alt tab...
