Right Click Items on desktop problem
    Hi
    I'm running Windows 8.1 and recently encountered a strange problem
    When I right click on an item on my desktop (file /folder etc) the screen quickly goes blue (the same colour as my Windows tiles as if it is switching to tiled mode rather than desktop) then my desktop comes back up.
    This also happens when I'm in a folder.
    It has started happening this last week. It is an annoyance to me as I need to right click >>> rename files all the time for my work but it wont work. As a result I have to open the file and go through the save as process instead.
    I have Avast and Malwarebytes Anti Malware - both have not picked up anything
    Any ideas?
    Many thanks
    (first post here so apologies if I haven't explained things well)
    Is that a "real" mouse or a touchpad ?
    Real mouse on a desktop non touchscreen PC
    Did you check in "Mouse properties" ? Mouse drivers ?
    What I should be looking for?
    The update drivers is greyed which I assume means they're up to date
    It doesn't seem to be a mouse issue as when I right click the sub menu pops up - it is when I click for eg 'rename' that the screen goes weird for a split second then back to the desktop
    Hmmm, how about it if you change background color from Automatic to another, permanent one. ? There might be some slight delay while it checks which one to use.
    Didn't work either I'm afraid. Just to clarify anything I do click on after right clicking doesn't work.
    Quote Originally Posted by grayggr View Post
    Something must have gone scroooowy with the system, why don't you try some of this medicine
    SFC /SCANNOW Command - Run in Windows 8[1]=Performance%20Maintenance
Solved desktop does not display items in Performance & Maintenance
If I make a shortcut, or drag a file to desktop, it doesn't display. but I can see it in the desktop folder. what's up with that?
This automatic update just happened and when I get back onto my computer most of the docs and others I had saved to my desktop are not there, and I can't seem to find them easily, any suggestions.
Just purchased 9 new Lenovo M93z all-in-ones. Have set up 7 of them and I'm having a problem with one that won't allow users to right click on desktop. On a windows domain network and users should be able to login on any pc. Logins work for everyone but on this one pc, half the users cannot right...
I've used TweakUI since Windows 9x to easily remove Right Click New items, for example, all MS Office entries pictured below. 15302 TweakUI 64-Bit does not work on Windows 8 and so-called Tweak software like Ultimate Windows Tweaker lack this feature. Programs such as ShellMenuView do not...
Anybody ever seen anything like this? Seems to have started after the 8.1 upgrade. 29883
Can't click on desktop (explorer) in Performance & Maintenance
Guys, i really want to solve this problem, see what happens: Everytime i turn on the computer he goes to the start screen, there, i can do everything... open apps run from side to side and etc... then i click in the desktop, when i get there i cant click any icon, there's no highlights not even in...
Solved click and drag to desktop in General Support
Please bear with me. Windows 8 is new and I previously used windows vista. I downloaded my games to an external drive. When I use external drive I display all games on the drive. I would like to drag 1 game to the desktop to be able to play at leisure. When I click and drag to desktop it copies the...
