Right click metro problems.
    Windows 8.1 Pro x64
    Problems with right clicking in Metro UI.
    Hi,
    Recently i got a problem that right clicking an app won't bring the menu bar (or whatever you might call it at the bottom of metro UI so now i don't know how to pin/unpin a program from start page
    No bottom bar after rightclicking an app.
    Any ideas how to solve this issue, thanks in advance.
    Windows 8 Pro - 64bit
    Are you using a custom theme? Maybe it doesn't support Update 1 yet. Switch to default theme and check if it's solved.
    Windows 8.1 Pro x64
    Quote Originally Posted by iNoPhone View Post
    Oh, thanks, that's indeed the problem, i didn't know that they turned the bottem bar into right-click menu.
So i know windows 8 should have an icon that should replace the place that kind of like square bracket in this photo27156
Solved Metro Right Click Menu issues in General Support
Hi, I recently installed Windows 8 Pro, and set my account type to Local. After a few days, I changed the type to a Microsoft account. After doing this, I noticed that whenever I right-click on an icon in the Metro interface, the icons of the context menu do not come up. I've attached a...
I have a new HP Windows 8 Pavillion Desktop. This morning when I click on any Metro page tile it flips as if going to Mail or People or Weather, etc. then flips right back to the Metro page. I called HP and they say it's corrupted and I have to call MS? I did this "refresh" thing once with this pc...
I tried that as is in the tutorial. Disable/Enable Metro was added to the context menu, but if I click it the following error message was returned: Script: C:\Windows\Toggle_Disable_Enable_Metro.vbs Line: 3 Chan: 1 Error: Unable to open registry key...
Hello, My Metro Applications and PC settings don't start after i click in it... I click on the icons and the application don't start. The Metro applications were working fine, but they stopped working. Anyone have this problem or anyone know how to solve it? Thanks
Problems with Metro apps in Software and Apps
I am using W8 Pro (French + US) retail. Clean install. Activated. UAC on. No driver issue. System is working correctly except some Metro apps. Metro applications pinned are updating correctly, all seems to work. Mail, explorer are working flowless. When I try to open for example Bing Meteo or...
Mouse click to invoke Metro UI in General Support
Mouse click to invoke Metro UI If you have a mouse with programmable buttons: The Windows Key is 'ctrl-esc' I have a Logitech mouse with programmable buttons. In the Logitech button settings you can program any button to go to the Metro UI: 1.) Go to your mouse settings; 2.) Choose a button; 3.)...
