Can Someone Help ME to Fix This Problem???
  1. #11
    Germany/Florida
    Vista and Win7
    Quote Originally Posted by Jefrz View Post
    then maybe some solution?
    download in this link ???Emergency Kit - save your files from a dead OS - Windows 7 Help Forums
    if i already download ...
    where i should install the program??? other laptop???
    If you want to use a tutorial, you have to read and watch it - which you apparently have not done.
  2. #12
    USA, Idaho
    Win 8, (VM win7, XP, Vista)
    If you need to save files (.doc, exl, mp3, etc.) then if you have the ability to create a Linux Live Disc do that; once that has been done restart your computer with the Linux live disc and then save all the files you want or can't live without onto an external device. After that then do as the others have said, and that is reinstall your OS's. Sorry, albeit that is your only course of action. . .good luck.
  3. #13
    Windows 10
    edit: How to fix the Windows 7/8/8.1/10 bootloader if the hard drive has an MBR (Master Boot Record) partition table. -> link
    I deleted system reserved partition.
    - Boot the computer using the Windows 7/8/8.1 installation media.
    - On the first screen, press SHIFT+F10 to bring up command prompt.
    - Run the following commands at the command prompt.
    diskpart
    select disk 0
    list partition
    select partition # Note: Select the partition where the Windows OS is installed.
    active
    exit
    bootrec /fixmbr
    bootrec /fixboot
    bootrec /rebuildbcd
    - Remove the Windows installation media and restart the Computer.
    If Windows does not start and you receive the error message "BOOTMGR is missing", then copy the bootmgr file from the Windows installation media to your Windows OS partition root directory.
    diskpart
    list volume Note: Note the volume letters.
    exit
    (these instructions assume your DVD drive is D: and your Windows OS is installed in C: drive)
    copy D:\bootmgr C:\
    Note: Do not copy the bootmgr.efi file.
    bootrec /rebuildbcd
    The bootrec /rebuildbcd command will search for Windows installations not included in the Boot Configuration Data (BCD) and then ask you if you'd like to add one or more to it.
    You should see one of the following messages at the command line.
    Option 1
    Scanning all disks for Windows installations.
    Please wait, since this may take a while...
    Successfully scanned Windows installations.
    Total identified Windows installations: 0
    The operation completed successfully.
    Option 2
    Total identified Windows installations: 1
    [1] C:\Windows
    Add installation to boot list? Yes<Y>/No<N>/All<A>:
    If you see:
    Option 1: This result most likely means that Windows installation data in the BCD store exists but bootrec couldn't find any additional installations of Windows on your computer to add to the BCD.
    Option 2: Enter Y or Yes to the "Add installation to boot list?" question.
  4. #14
    8284
    I'm having the same problem as well. First off, when I turned on my computers and I wait for a couple of minutes, all I see was my mouse cursor and my screen was black. Then, i system restore/reboot, (loosing all of my information), which took 2-3 hours. When it was finished, I restart my computer just to see if it was working perfectly then this happened:
    Check cable connection!
    PXE-MOF: Exiting Intel PXE ROM
    Reboot and Select proper Boot device
    Or Insert Boot Media in selected Boot device and press a key
    I turned off my computer by holding the power button, I hold/tap the F2 and to see if my hard drive has been corrupted or died off, couldn't find the hard drive.
    This problem happened 2 days ago, before it happened, my computer was working fine. (I had my computer for about 2 years)
    Please reply back with any suggestions what I should do.
    (ASUS Desktop)
  5. #15
    United States
    Windows 8.1 Pro 64-bit
    Quote Originally Posted by Ghgh View Post
    (ASUS Desktop)
    Welcome to the forum!
    Sounds like you need to check all your connections inside the computer and your power supply. Make sure hard drive is firmly in socket. Has the computer been moved, maybe knocked a bit?
  6. #16
    8284
    My computer hasn't been moved or knocked. How do you find the connections inside the computer or the power supply? My computer is similar to a Mac, or All-In-One Desktop.
    I hope I'm not confusing you or anything.
  7. #17
    win8.1.1 enterprise
    as for taking apart you computer ,all in ones are like big laptops ,you need to check for directions in a manual or how-to direction on the web as to how to take it apart to check your connections ,check the back of the case ,there may be a cover to remove to gain access ,or take it to computer repair shop and have them do it .
    what is the exact model number, that should also be on the back of the case
Page 2 of 2 FirstFirst 12
Here is my problem When i write my DVD-R with Nero/Imgburn/Burnaware it says burnt successful but it fails to verify and even dvd is blank when i reinsert in laptop and my friends computer. I have tried to burnt at slower speeds but still same problem.:rolleyes: My dvd drive reads other DVDs...
When I try to check for a solution to a problem (Control Panel\System and Security\Action Center\Problem Reports) a warning appears telling me to connect to the Internet or to try later… 44832 The problem is that I am connected to the Internet while I receive this message and now I do not see...
I have 2 issues. I don't know if they are related somehow. 1. I installed PrivaZer and deleted it. It still shows up on the right click context menu. I tried to reinstall it and deleted it again. I still have that problem. I even restarted the computer. How can I get rid of the entry? 2....
So i'm trying to delete this file i have in my downloads folder, which is a normal .avi file. however, this file is really broken, it wont delete. I suspect this file makes my folder not showing thumbnails and acting slow and sometimes wont show anything at all, just a loading bar thing. i...
Hey, running Windows 8.1 64bit, Asrock Z87E-ITX mobo, Intel 4770K Problem 1: When i shot down my pc via windows Shot Down button pc doesn't go Off. I see Windows Off screen, screen goes black but pc still running. Solution? Problem 2: When my pc goes sleep or monitor goes sleep i can't...
I had no problems with Customer Preview, everything worked, but, I must say that this Release Preview is another story all together. My PC hardware configuration is unchanged since installing Windows 7 when it came on to the market. 1. Doing a clean install did not install a clean...
