Solved Ihave A Big Problem Please Help!!!!!
midou35000
Coming Over
Canada
hi guys,
i have a windows 8.1 and it was the first thing i connected it to the router then i wasnt able to connect any other samrtphone or TV or tablet ony when i connect to it using this computer and if i didnt do that on another device it will not connect to it saying that it couldnt connect to this wireles network
Ihave a
EchoLife HG520b
any idea
THanks
    Windows 10
    HP
    Intel Core i7
    Nvidia Geforce GTX 680
    idfk
    15' 1080p display
    70Mbps
    Google Chrome Canary
    AVAST Premiere 2015
Not really following you. You are stating that no other smartphones or computers will connect to the router, unless your computer is connected.
What is the manufacturer & model of the router, who is your ISP.
    Linux Mint 17.2
    12GB
    AMD Radeon™ HD 7310 Graphics
    Realtek HD
    LCD
    1366 x 768
    Crucial M500 240GB SSD
    Logitech M525
    45/6 - ATT U-Verse
    None needed. It is Linux.
EchoLife HG520b thats my router model
    Windows 10
    HP
    Intel Core i7
    idfk
    15' 1080p display
    70Mbps
    AVAST Premiere 2015
Your going to have to post a more detailed description of your problem than that. What is your router connected to too get Internet? Is that device connected to the WAN port of the router? How are the other PC's connected to the router, wired or wireless? Do they not connect to the router or do they just not get Internet?
    Windows 10 Education 64 Bit
    Asus
    Thermaltake TR 620
    Stock heatsink fan
    Logitech Wireless K350 Wave
    80 Mbps Down 30 Mbps Up
alphanumeric am sorry of not giving a detailed post because am in hurry of my self anyway i wanted to say that ihave a windows 8.1 and it was the first thing i connected it to the router then i wasnt able to connect any other samrtphone or TV or tablet ony when i connect to it using this computer and if i didnt do that on another device it will not connect to it saying that it couldnt connect to this wireles network
    Windows 10
    HP
    Intel Core i7
    idfk
    15' 1080p display
    70Mbps
    AVAST Premiere 2015
I'm still not totally following what you said? You need to break that one run on sentence up with some punctuation. Is this a new router that you are setting up for the first time? Is the network password protected?
    Asus
    Thermaltake TR 620
    Stock heatsink fan
alphanumeric yes it is secured and what i wanted to tell you that nothing gets connected to the wifi network unless i turn on my laptop and connect to it or no other device will connect to the wifi network
    Windows 10
    HP
    Intel Core i7
    idfk
    15' 1080p display
    70Mbps
    AVAST Premiere 2015
It sounds like your laptop may be running in a hotspot mode and your other devices are actually connecting to the laptop. Turn the laptop on and turn the router off. Then see if another device connects to your wireless network.
    Asus
    Thermaltake TR 620
    Stock heatsink fan
alphanumeric yes my laptop is on and router is off and they are connected so what should i do
    Windows 10
    HP
    Intel Core i7
    idfk
    15' 1080p display
    70Mbps
    AVAST Premiere 2015
There must be a hotspot utility running on it. You'll have to find it and turn it off. This type of utility lets you share your internet connection with other devices. It basically turns your laptop into a wireless router/repeater. There is likely an Icon for it in the notifications area down next to the clock on the taskbar. I'd look there first.
    Asus
    Thermaltake TR 620
    Stock heatsink fan
ummm idont know how to turn it off
    Windows 10
    HP
    Intel Core i7
    idfk
    15' 1080p display
    70Mbps
    AVAST Premiere 2015
Did you actually find it? I'd have a look at your owners manual to see if it's mentioned there. If it is there should be instructions on how to turn it off. Have a look at the tiles on your Start Screen including the All Apps screen.
    Asus
    Thermaltake TR 620
    Stock heatsink fan
alphanumeric i didnt find anything even the owners manual in all apps section
    Windows 10
    HP
    Intel Core i7
    idfk
    15' 1080p display
    70Mbps
    AVAST Premiere 2015
Check the settings for your wireless adapter. Another option is to change the name of your wireless network on the router. Then leave your laptop off and connect your other devices to the new network. Then connect with the laptop last.
    Asus
    Thermaltake TR 620
    Stock heatsink fan
Thank you alphanumeric
    Windows 10
    HP
    Intel Core i7
    idfk
    15' 1080p display
    70Mbps
    AVAST Premiere 2015
