Any hope for 8.1 Power Management Settings/options???
cognus
Texas
I note a zillion angry threads to MS re: the Power Mgmt issues in 8's.
anyone know workarounds?
I've been working with 8.1 on a notebook, where all devices luckily are installed right and functioning right, until I go trying to make it play nice as a HTPC system... USB-attached HID/kbd/trackpad, HDMI-out to big HDTV, AC Powered, but no matter what I set, it still does as it wishes, losing the USB devices 100% of the time.... etc
anyone clue?
    Win 8.1, Win 10P, Win7-all, RIP XPP, 'droid 2.2, 2.3,4.x, 5..IOS,
    many: E5440, 430 G1, E45, G4-1117DX, X120E, DC7600, X83VB-X2, NC10, Droids, Galaxy,
    too many
    ditto
    ditto
    ditto
    30mbps
Try turning off power saving features in the BIOS if you can and let Windows manage it only. Mixing those options in BIOS and Windows can produce unexpected results with some of the setting taking precedence over others.
    Home made
    AMD Ryzen7 2700x
    Asus Prime x470 Pro
    16GB Kingston 3600
    Asus strix 570 OC 4gb
    Samsung 960 evo 250GB
    Silicon Power V70 240GB SSD
    WD 1 TB Blue
    WD 2 TB Blue
    Bunch of backup HDDs.
    Sharkoon, Silent Storm 660W
    Raidmax
    CCM Nepton 140xl
    40/2 Mbps
    WD
what i've done for the time-being is setup the "High Performance" plan to basically do nothing but spin down the drive and turn off the display when on AC Power. thankfully, it works. its the only setting of any kind I could do to avoid sleeping when the lid is closed [that seems to override everything else - like the master trump card]
updating BIOS on a samsung is another story.... scary stuff
    too many
    ditto
    ditto
    ditto
    30mbps
