plz help me out..... by solving my problem
    india
    my problem is this that... i have deleted my one software application without uninstalling that no if i reinstall this software or trying to delete it through control pannel, then it will show me a ''unable to locate the installation log file -----uninstallation cant be completed''...
    plz suggest me some solution... to uninstall/remove it completely from control pannel...
    dehradun
    window 8 pro (64bit)+ window 7 ultimate (32bits)
    try "Revo Uninstaller Pro " software
    india
    Is there is no any other way to uninstall it...
    You have a registry string left over in the registry from the deletion. Look in "HKEY_CURRENT_MACHINE" and "HKEY_LOCAL_MACHINE" under software and look for the software and delete the folder in each area listed above.
    WARNING: WORKING IN THE REGISTRY CAN BE FATAL TO YOUR SYSTEM!!! Just be very careful if you decide to take this action.
    If you're not comfortable doing that, you can see if the software you deleted has a(n) special uninstaller tool from the software's manufacturer and run that. Or use Ccleaner and run it's registry cleaner...it's free and many users of the software use the registry cleaner with lots of success.
    CCleaner - PC Optimization and Cleaning - Free Download
    Can you download the program again and reinstall it.
    That's worked for me and I think because it reestablishes everything in the registry and the program's folder. Including the uninstall information.
    Quote Originally Posted by ANJALI SHARMA View Post
    What software are you talking about?
    Quote Originally Posted by pcRat View Post
    I've done this before as well. You reinstall the application on top of the failed uninstall. And then uninstall the whole thing.
    Quote Originally Posted by dirtyvu View Post
    I recently ran into a problem that that method didn't work, and to beat all it was with skype. I had to go into the registry, find all skype folders and delete them, reboot, re-download and reinstall....all fixed.
Here is my problem When i write my DVD-R with Nero/Imgburn/Burnaware it says burnt successful but it fails to verify and even dvd is blank when i reinsert in laptop and my friends computer. I have tried to burnt at slower speeds but still same problem.:rolleyes: My dvd drive reads other DVDs...
When I try to check for a solution to a problem (Control Panel\System and Security\Action Center\Problem Reports) a warning appears telling me to connect to the Internet or to try later… 44832 The problem is that I am connected to the Internet while I receive this message and now I do not see...
I have 2 issues. I don't know if they are related somehow. 1. I installed PrivaZer and deleted it. It still shows up on the right click context menu. I tried to reinstall it and deleted it again. I still have that problem. I even restarted the computer. How can I get rid of the entry? 2....
After sfc /scannow CBS.log : https://www.dropbox.com/s/cvc964h5jklc70m/CBS.log After perfoming : dism /online /cleanup-image /restorehealth (error 0x800f081f) Dism.log : https://www.dropbox.com/s/j0925pkm3tjtl78/dism.log After perfoming : Dism /Cleanup-Image /Online /StartComponentCleanup...
Solving Longitude problem in Chillout Room
Hi there Just thought this little snippet might be of interest to some budding physicists here -- some of the crazy ideas in the past of how people attempted to solve the issue of LONGITUDE for navigation in days gone by. I always like looking at this sort of stuff when things get very quiet in...
I just got a new desktop yesterday. It is a computer from CyberPowerPC with Windows 8 64-bit. I have been unable to connect to the wireless at all, however I can connect to the internet with an ethernet cable. I have reinstalled my network card drivers, the network card is a RealTek PCie GBE...
I had no problems with Customer Preview, everything worked, but, I must say that this Release Preview is another story all together. My PC hardware configuration is unchanged since installing Windows 7 when it came on to the market. 1. Doing a clean install did not install a clean...
