Start Up Problem Please Help
    Windows 8 64
    Okay so a few hours ago I accidentally held the power button down and it shut off my computer. Now it wont come back up. Every time I turn it back on it trys to repair its self and it fails. And then it just restarts over and over and never gets anywhere. Sometimes it will pull it up to the restore screen and I click restore and it says it has to restart and never gets anywhere. Im pretty computer smart and this one has me lost.
    Please help thanks
    If it's a laptop remove the battery and then reinstall it.
    Windows 8 64
    Its a desktop
    Quote Originally Posted by a274josh View Post
    Please help thanks
    Do you have an install DVD? If yes, try starting up to it and using the repair your PC link to repair startup from "outside" the hard drive. In this regard, see if system restore will work. Also, I am not sure which f keys do what on your machine, but use them to see if you can apply any fix/start up options--e.g., start to last known good configuration. After starting from your DVD if you have one, you may be able to use the SFC /SCANNOW command via the command prompt available via the repair your PC link. Check this command out here.
53107 this is the screenshot.You see "Start" letter is there and can't do anything about it. Left or right clicking doesn't do anyhting. It happened after i removed ViStart. I have tried reinstalling ViStart and removing it again but no changes. I am running Windows 8.1 Pro x64 Waiting...
start up problem in General Support
Hi i found some errors on my pc can anybody tell me what these are or how to fix them my pc hangs on the black screen for up to 8 minutes then it starts ? Application errors: ================== Error: (08/27/2014 08:44:08 PM) (Source: Microsoft-Windows-CAPI2) (User: ) Description:...
win 8.1 start menu problem in General Support
Hi, For some reason when I click on the start menu using the left or right button, nothing happens. Does anyone have any ideas of fixes? Thanks Artoo
KMS GUI ELDI start-up problem in Software and Apps
Hi all, I was using windows 7 for long years but i have installed windows 8.1 pro recently. I have installed Ms Office 2013 professional plus as an illegal with KMSNano portable. Now, i bought original product key but just before loading i realized that at windows start-up a program KMS GUI ELDI...
problem with start up in Performance & Maintenance
I'm using windows 8 pro x64 I install it two days ago, before I format it there is a problem I think with format it will go but that's not true. when I turn it on and before the lock screen shown, I heard the start up sound but it be black screen and there is nothing change. also caps lock and...
Start menu problem in General Support
Hey, I have a problem whit my new computer on windows 8. Today I turned on the computer, I login, but then, the start menu app's doesn't work anymore! When I wan't to open skype it doesn't work, when I click on desktop it doesn't open.. I need to click on the windows button every time. I...
Problem with Start screen in Customization
Hey boys and girls! I have a little problem with my start screen, it has been doing just fine until recently when all my apps got weird, only the appicture, not the app itself. I'll show you a photo.9485. See how the apps are not in high resolution. That happened a while ago and a couple of days...
