G'day everyone,
Just thought I'd see if anyone has had similar issues to me....and, more importantly, ways to fix them
Basically, I have three main problems with Windows 8. They are:
1. Monitors don't always work. I have 4 monitors, 2 DVI, 1 minDP and and USB. On reboots or if a monitor is turned off and on etc, one of the DVI monitors refuses to work. I've tried many things to correct it, and sometimes it does come back
Once they are all on, they are fine.
2. Lockups. Sometimes windows just freezes....not everything, just whatever I was using when it froze...ie..sometimes it is windows explorer, sometimes taskmanager etc.
It seems every time I boot I get another little problem....last one was...a blank start screen....windows key put me to desktop, windows key again....blank screen....it eventually came up....don't know why
Some general info:
OS was done as a full install onto an SSD.
Video drivers are up to date from AMD. No other drivers have been updated, other than what windows found for them.
Hardware is: Asus p8z77-v-pro mobo, 32G 1866 RAM, i5 3570k, AMD HD 6570.
So, does anyone have any ideas? Thank you in advance!
Some general info:
- win 8 x64 pro
