Solved Problem with product key
rawiggs
Roswell, GA
I bought two boxed versions on Windows 8 Pro with the discs. I installed a 64 bit version on my Toshiba laptop and a 32 bit version on my desktop. After installation, I downloaded Windows Media Center on each machine using my Windows Live account. After installing Media Center, I ran Belarc Advisor on both machines. To my surprise, both machines now show the same product key. I contacted tech support at MS and the guy told me there shouldn't be a problem, but it seems weird that both machines now have the same product key and it is not the key of either of the boxed versions I bought. Anyone think this will cause problems down the road?
    intel e5200
    gigabyte
    4 gb
    nvidia
Did you use the same key when you install Media Center on both?
    Intel i7 3770K
    Gigabyte Z77X-UD4 TH
    16GB DDR3 1600
    nVidia GTX 650
    Onboard Audio
    2560x1440 + 2x 2048x1152
    Antec SOLO II
    Logitech MX
No. I used different keys from the Media Center downloads. The MS rep said it was because I used the same Windows Live account for each download. I only have one Live account and really don't want to setup another one.
    intel e5200
    gigabyte
    4 gb
    nvidia
Hmm.. weird. No, i don't think it will cause any problems.
    Intel i7 3770K
    16GB DDR3 1600
    nVidia GTX 650
    Onboard Audio
    Antec SOLO II
    Logitech MX
