messagetyper
Every time I open task manager my CPU usually says it has 68-88 processes going on, and is usually sitting at 35-40% usage, sometimes even reaching 50. Is there a fix to this? The process that seems to be taking a lot is this "Service Host: Local System", is it safe to end this?
The CPU that I'm using is an i5 4590. OS would be Windows 8.1 Pro x64. Thanks.
- Windows 8.1 Pro
- Computer type
- PC/Desktop
- CPU
- i5 4590 3.30 GHz
- Memory
- 4GB
- Graphics Card(s)
- Zotac GTX 750 Ti 1GB
- Screen Resolution
- 1366 x 768
