4 pin power supply problem
RLSARC
www.RLSARC.xyz
a friend of mine hand me his system unit to reformat. when i get home i back up all his data in D:\. i winrar his 40+gb data into 7gb/ part cuz i only have 2 8gb usb drive so 40/7=6 parts aprox. when the compresion is in part 4, the system unit starting to warm for 3 hours. the compresion is in the last part, which is part 6 when sudenly the system unit is dead. its like a brownout. i press power on but avail. i dismantle the sys unit and it smels like ironing clothes and its very HOT. i leave it for 30 mins and put back the parts (not hot anymore), the heatsink spins but no visual on monitor. when i look back the board. the 4pin (i dont know what it is called but it has 2yellow and 2 black wire) is not connected. when i connect the 4 pin, the heatsink wil not spin. please help me fix this. im not into hardware.
whats the appropriate solution for this problem? hoping for your kind help.
EDIT: The board is GeForce6100PM-M2 v2.0 the heat sink has a stikcer of amd and i cant determine the powersupply cus it not the usual location. its power supply is below the hdd.
    Microsoft Windows 8.1 Pro 64-bit 9600
    ASUSTeK Computer Inc.
    Intel(R) Core(TM) i5-2500 CPU @ 3.30GHz
    ASUSTeK COMPUTER INC. P8H61-M LE
    4.00 GB
    Intel(R) HD Graphics
    Realtek High Definition Audio
    Samsung SyncMaster SA300
    1600x900
    WDC WD10EARX-00N0YB0 ATA Device
    Genius KB110
    Logotech B100
    5 MBPS
Without information on the case, not able to help you.
    Linux Mint 17.2
    12GB
    AMD Radeon™ HD 7310 Graphics
    Realtek HD
    LCD
    1366 x 768
    Crucial M500 240GB SSD
    Logitech M525
    45/6 - ATT U-Verse
    None needed. It is Linux.
you mean the chasis? how to find out its info? tnx for the reply and please help me further. :)
EDIT:here are some photos of his sys unit. sorry for long post. NO SPOILER TAG here @ 8F
im afraid that the mobo has the problem. :cry:
    4.00 GB
    1600x900
    Genius KB110
    Logotech B100
    5 MBPS
I was gonna suggest to use another power supply and noticed you've already done that. So yes, I think the MB is fried.
    Home Brewed
    I7 4970K OC'ed @4.7 GHz
    MSI-Z97
    NVIDIA GeForce GTS 450
    Dual HP-W2408
    1920X1200
    Antec 850W
    Antec 1200
    Danger Den H20
    Logitech
    Logitech Performance Mouse MX
    35/12mbps
is there a way to tweak the MB to work again? :cry:
cant afford to buy a new one. just a student wanting some extra cash for school. hehe. i hope the owner wouldnt get mad @ me. BTW tnx for the help. appreciate it.
    4.00 GB
    1600x900
    Genius KB110
    Logotech B100
    5 MBPS
You can try to take the whole MB out of the case and test again to make sure that it is not shorted. If it does not work then you'd have to replace the MB. I don't think you can find any where that they can do MB repair. It would cost a lot more and time to do this kind of job.
    Home Brewed
    MSI-Z97
    Dual HP-W2408
    1920X1200
    Antec 850W
    Antec 1200
    Danger Den H20
    Logitech
    35/12mbps
Thanks. I'll try this. I'll get back here soon. :thumb:
UPDATE: HMOG! when i take the MB out. I just found out that the foam (What type of foam is that? What is it called?) is melted.
Question. Why do they put the foam? is it necessary? The foam melted in the MB, does the MB has a chance to function again?
Waiting for your kind reply. Tnx
    4.00 GB
    1600x900
    Genius KB110
    Logotech B100
    5 MBPS
