USB 3 20 pin disconnects and conects with front hub..HELP
    widows 8.1
    Hey all, I just built a system with the asus sabertooth 990fx r2.0 and the amd fx 8350, 32gb ram with windows 8.1 and it came with the latest bios. My problem is since I built it last week ever 1-3 minutes the beep beep noise of a usb device disconnects and reconnects right away. In the device manager I can see that one of the generic usb hubs disappears and reappears. I started by disconnecting all the usb stuff hooked to the back of the computer and still did it.
    Unplugged both usb header leads on the board and still did it. So last night I unplugged the 20 pin usb 3 header on the board and it stopped. I have a raidmax 3.5 usb hub plugged in there. I could find nothing in the device manager about usb 3 controllers but I did download the latest usb 3 drivers off of asus website but still did it. On raidmax website it states that the hub I have does not need and drivers. Soooo I have at the end of the road of what I think it could be. Does anyone have a clue what could be causing it to disconnect and reconnect every few minutes. Thanks and Please HELP!!!!!
    ps, just signed up and alot of good info on this forum. thanks I read through about 20 pages of a search for usb 3 with not end result...
    Windows 8.1 Pro/LinuxMint/Mac OS X
    IF you have raidmax connected to the port that keeps disconnecting it could be the raidmax going in and out. Try it without the raidmax connected and let it run see if it still happens.
    If it does it could be ports physical connection (bad wiring on it ) it sounds like you are describing the usb ports on the front off your case. Is this right?
    If that is the case make sure the usb connectors are properly seated on the motherboard.
    WAX
    widows 8.1
    yes it is in one of the 3.5 drive spots in the front and has one 20 pin connector that connects to the mother board. If I unhook it from the motherboard the dinging goes away. Food for thought, I was looking at other brands and I noticed that this one Bytecc UH-430 4-Port SuperSpeed USB 3.0 Internal 3.5" Bay Hub UH-430 - Micro Center has in the description "Internal USB 3.0 Interface; 4-pin Molex Power Connector" The Raidmax only has the one usb3 cable and no led light.... soooooo I wonder if due to its not getting a power supply it might be doing it? any thoughts?
    widows 8.1
    but I see it does not hook to the header it hooks to one in the back...humm
Hi. I have so many problems with windows 8.1 i have seriously no idea where to begin. First one i would like to have fixed is this damn sound, happened to me first time i installed windows 8.1 aswell, and i have no idea how i fixed it. The speakers are set to Quadraphonic, i have tried all...
Hey guys i bought hpx705w usb 3.0 drive.Its not working in front usb ports of my desktop but works fine when plugged in back usb ports.And also works fine on my laptop usb ports. What should i do ? Running windows 8
No sound from front panel in Sound & Audio
Yeah so my front panel is connected to my board but im still not getting any sound Usually in the good'ol versions i would disable front panel detection from the realtek driver utility but i dont have that on this computer
Alright, so I've had this problem ever since I upgraded to Windows 8. I was initially a Windows Vista user, and this headset worked perfectly fine on the Vista Home Premium OS. However, ever since my upgrade to Windows 8 Pro the microphone refuses to pick up sound. I have done everything from...
Front panel no left sound in Sound & Audio
Hello, I've got an Z77 Pro3 mobo (Asrock) and a Bitfenix Shinobi case. I've installed the HD-audio plug from the case to the motherboards hd-audio place correctly. My problem is that the case's front panel gives sounds only to my headsets right side but not to the left side. The microphone...
Read ALL about it here. Can Office 365 convince you that renting software is a good deal? | ZDNet :mad:
