Power up problem
    Power up problem
    Hey guys
    I woke up today to power up my laptop, but for some reason, it failed.
    The power button didn't show the usual light it shows when it's on.
    I removed the battery, unplugged my laptop, held down the power button for 30 seconds, plugged my charger, nothing happened, still couldn't turn it on. (Used an online guide to do that).
    After I kept the battery out of the laptop for about 15 minutes, I put it back in and the laptop started by itself (yes, weird).
    Out of curiosity, I wanted to see if I managed to fix my problem, so I shut down my system, and it actually restarted instead of shutting down. I couldn't get it to shutdown.
    I pressed the power button to shut it down, and after that, I couldn't get it to start up again.
    I repeated the first procedure I did (left battery out for 15 minutes), and now I'm here, scared of shutting down my laptop again.
    What might be causing this?
    Is it a hardware or a software problem? (Or both?)
    What can I do to fix it?
    Did you try running without battery connected ?
    Yes.
    Tried without battery, with battery. Nothing.
    What's weird is that I can get it to power up when I remove battery and put it back in after like 15 minutes.
    Last night, I shut it down and thought it worked. After an hour, it woke me up because the laptop turned on by itself.
    Weirdest thing ever.
    Gremlins, ghosts, faulty battery sensor or contacts ?
    O.o what? lol
    Quote Originally Posted by TripleR View Post
    O.o what? lol
    Most batteries have heat and/or voltage sensors or contacts may be slightly corroded and hence some delayed actions.
    O.o what? lol
    I thought about that. Should I buy a new charger and battery as a first step to troubleshooting this issue? My battery isn't doing very well anyway..
    I don't know, charger first maybe.
    It's not a software problem though right?
    Well, software comes into play only AFTER computer is started.
Page 1 of 2 12 LastLast
Power up problem
How to Add or Remove "USB 3 Link Power Mangement" in Power Options in Windows 8 What is a link A USB connection between two USB ports. For example, between your PC and a USB 3.0 device. The downstream port (DS port) of a host or a hub. The upstream port (US port) of an attached device...
Hello, I have my Windows 8.1 setup so the display turns off in 1 minute. I have the power options setup so that the power switch shuts the system down. But it doesn't. If the screen is off and I press the power switch on my PC the screen comes back on. I then need to press the power...
Power Save problem? in Performance & Maintenance
I installed Windows 8.1 a month or two ago. I can't say I like the general look of it but it seems reliable enough. However.... About 4 times each day, my hard drive will 'stall' very briefly (as if the power's been removed) and then immediately start up again a fraction of a second later. When...
I have WIN 7 and WIN 8 with automatic updates turned on as recommended by MS. It is very annoying when you want to shut down and go in a hurry, you see this message saying 1 of xx updates, do not power down.... You don't normally shut down unless you want to go and this is delaying you from doing...
Windows 8 power option problem in General Support
AOA frnds i have hp notebook with windows 8 OS. when i plugged in the charger the display totally disappears and the screen has black for only 1, 2 seconds. and the same situation is when i removed the charger. but this is not happened when i was using windows 7. is this a problem or a feature...
