Power up problem
  1. #11
    Quote Originally Posted by TripleR View Post
    It's not a software problem though right?
    Well, software comes into play only AFTER computer is started.
    I was thinking there might be something running in the background that is causing laptop to fail at shutting down.
  2. #12
    For shutting down yes, usually some ill behaving driver.
Page 2 of 2 FirstFirst 12
Power up problem
How to Add or Remove "USB 3 Link Power Mangement" in Power Options in Windows 8 What is a link A USB connection between two USB ports. For example, between your PC and a USB 3.0 device. The downstream port (DS port) of a host or a hub. The upstream port (US port) of an attached device...
Hello, I have my Windows 8.1 setup so the display turns off in 1 minute. I have the power options setup so that the power switch shuts the system down. But it doesn't. If the screen is off and I press the power switch on my PC the screen comes back on. I then need to press the power...
Power Save problem? in Performance & Maintenance
I installed Windows 8.1 a month or two ago. I can't say I like the general look of it but it seems reliable enough. However.... About 4 times each day, my hard drive will 'stall' very briefly (as if the power's been removed) and then immediately start up again a fraction of a second later. When...
I have WIN 7 and WIN 8 with automatic updates turned on as recommended by MS. It is very annoying when you want to shut down and go in a hurry, you see this message saying 1 of xx updates, do not power down.... You don't normally shut down unless you want to go and this is delaying you from doing...
Windows 8 power option problem in General Support
AOA frnds i have hp notebook with windows 8 OS. when i plugged in the charger the display totally disappears and the screen has black for only 1, 2 seconds. and the same situation is when i removed the charger. but this is not happened when i was using windows 7. is this a problem or a feature...
