Cooling Fan Help
    Cooling Fan Help
    Hi, since I'm thinking of overclocking my CPU for better performance, I thought, "Well instead of overheating my motherboard and destroying a 600 dollar laptop, why not get a cooling fan?" So I went out looking for one. I found this:
    Cooler Master NotePal X3 - Gaming Laptop Cooling Pad with 200mm Blue LED Fan
    Will it work with my 17.3 inch laptop? Please help! If not, can you find me a cheap cooling pad that provides maximum cooling so my laptop wont overheat? Thanks!
    Quote Originally Posted by MCPlayer18 View Post
    It should work and help somewhat but don't expect miracles eh. They work of USB port so battery time will suffer. It's most important to keep insides of laptop clean and not put it on any soft surfaces that may cover cooling grills underneath.
Cooling Fan Help
Extrernal Fan/Cooling Pad? in Performance & Maintenance
I have a question to ask. I overclocked my laptop VIA AMD Overdrive and am worried about overheating. My CPU is fine but my GPU is at around 50 Celscius on average. Is there any cheap and good gaming external fan/cooling pad? For a 17.3" Laptop. Thanks!
My laptops cooling fan has kicked on once since I've had it and that was a little bit after turning it on for the first time. How often should a laptops cooling fan kick on?
Liquid Cooling Intel RTS2011LC in Drivers & Hardware
I bought one of these Intel CPU coolers about 3 years ago, RTS2011LC for my Asus P7P55 Mobo. At the time it was quite an improvement on air cooling (Hyper 212) when overclocking. I later upgraded to the ASUS P8Z77V-De Luxe and fitted the cooler to that machine. My PC is usually running 24/7,...
Solved CPU Cooling in Drivers & Hardware
Question about how my cooling seems, that it is adequately cooling well enough. Back in the late winter i installed a Arctic Freezer 13 Cooler Heatsink. I used Arctic Silver 5 to mount it. Avid room temp now are a bit warmer then in winter. I just wanted to check it again so i ran IntelBurn...
Win 8.1 and cooling fan in Drivers & Hardware
This is strange and infuriating. It seems that after doing up dates on windows, intel driver, nvidia around July and August 2014 my cooling fan will only work if each day I uninstall a win update and restart. Thats the simple version.
Possible bad cooling fan? in Drivers & Hardware
So a friend gave me a call saying that when his computer boots up it says "a cooling fan is not working properly and may cause problems", no error code. The computer he says gets hot and shuts down. I am assuming bad cooling fan however I have never had that message just a computer over heat. So...
Hard drive cooling in Drivers & Hardware
What unusual weather! I need some suggestions/advice for my new case rebuild. For those that don't know, I have plans to hold 15 hard drives in my new tower, through the use of hard drive cages, specifically these ones... Newegg.com - ICY DOCK MB453SPF-B 3 in 2 SATA I, II & III Hot-Swap...
