Intel Management Engine Interface Problem
    Greece
    Win8.1 64bit, Windows 10 TP on VMWare Player
    In Device Manager I have an ! against Intel Management Engine Interface.
    In Driver Properties it says:
    This device cannot start. (Code 10)
    An invalid parameter was passed to a service or function.
    I have also seen errors related to this in a recent Perfmon report.
    I have tried to update the driver (right click on it in Device Manager, check on Dell website, check with Intel Driver Update Utility) but all these methods say I have the up to date one.
    On my other Dell laptop (same spec) the same version of this is running without a problem. On that laptop there was an update in mid November that I don't have on the problem laptop. I have a feeling that I did a System Restore back around that time that affected a few things, and this may have been one of them. I thought I had kept a screenshot of this, but must have deleted it so I can't be sure.
    Question is: how can I get this working again?
    Should I try uninstalling and reinstalling it?
    If so, what is the best (and most foolproof) way to do this? Can I do it from the right click options in Device Manager, for example? I'm a bit concerned that, if I uninstall it I may not get the correct version back again.
    Windows 3.1 > Windows 10
    yes uninstall the driver until you get the ? mark for unknown device, reboot and reinstall the driver
    Greece
    Quote Originally Posted by KYHI View Post
    Thanks for this, KYHI.
    As I'm not very technical can I just clarify:
    • will I get the ? for unknown device as part of the process of uninstalling using the right click?
    • and from where do I reinstall the driver?
    I prefer to know what I'm going to encounter before I start down an unfamiliar road whenever possible .
    properties - uninstall driver
    download dell driver (extract) then click unknown device - update driver - browse - point to extracted dell driver ( this will load the driver only) not the app.. if you want the whole app - run the dell driver setup
    Greece
    Thanks for the clarification KYHI. Will have a go at this in the next few days and see if it does the trick.
    Greece
    Just uninstalled, which was slightly disconcerting as it installed the device as well as the driver.
    Rebooted and reinstalled and now I have a properly working driver again .
    Another one to tick off the list.
    Thank you KYHI
Are these 2 drivers system-specific, or can I bypass the OEM's outdated drivers and grab the latest versions straight from Intel?
I have been going crazy try to update my ASUS H81M-PLUS motherboard BIOS. ASUS is no help. Intel is no help. This might not be the right forum for this, but, I reached a point in the BIOS update (complicated) process where it now wants me to download the following driver for an Intel 4gen...
I seem to be in a loop while upgrading from a Pentium G840 to an i3770 K on an Intel DH61WW motherboard. It seems that I need version 8.x of Intel Management Firmware and I can't get to update past version 7.1.52.1176 According to this page, I need version 8.x to continue for updates to use...
I just bought this new Asus VivoTab Smart. The MS Windows Explorer works fine, it was already on the Start screen. I added 2 ordinary Google search engines, (one in the UK) to the Start screen. (Neither was a Google Chrome). When I try to use either one of them I get this message: "There is a...
Hello eightforum users, i Got an really big problem.. i just reinstalled my PC, obviously with windows 8. and i cant seem to play games, i mostly play COD4 and whenevery i join a game, i get an Dirextx error, or my PC just reboots.. i dont know if it has something to do with my LPC INTERFACE...
A Review of Intel Will Windows 8 evolve further that just touch?
Hello, I am trying to install the Intel MEI (Intel Management Engine) for the Asus P9x79 WS motherboard. I have had no issues installing this on Win7 x64. However, when trying to install the drivers in Win 8 x64 from the Asus install CD, I get a OS not supported message. There are no drivers...
