Solved No Post and No power LED
Gamer11
Closed as requested
so In many years in pc experience I noticed in my case I would know the day that my pc wont post
The normal post I look at the power LED on and H.D.D LED begins to blink as PC is starting
when they are suddenly off in the next restart I surely know that the PC wont post
IS there a link between the power led and Post ability
I am know at this case sometimes they turn on sometimes they dont
Trying to reset CMOS until they are on again after 10 times clearing
What is wrong?
Thanks
    Win 10 Enterprise X64
    Gamer11
    Intel Core i7 5930k
    ASUS X99 Deluxe
    4x4 G.skill DDR4 2133mhz
    GTX 780 Ti GHZ
    WD 2TB
    EVO 840
    Corsair 850w
    NZXT switch 630
    Corsair H110
    Avira
No, there's no real relation between the two, except that the power LED means that the system is powered up and will begin the POST process. In your case I'd say it sounds like your motherboard has bad caps. It's a common symptom where a computer may take multiple tries to boot and will stall somewhere during the POST sequence, but run perfectly fine when it does boot normally.
Unless you're extraordinarily skilled with a soldering iron, there's no way to fix this except to replace the motherboard, assuming it is indeed bad caps. A less likely, but still possible, explanation would be a failing power supply.
but why it dont give any beep code
tip: this case before was the cpu failing long time ago
    Gamer11
    Intel Core i7 5930k
    ASUS X99 Deluxe
    GTX 780 Ti GHZ
    WD 2TB
    EVO 840
    Corsair 850w
    NZXT switch 630
    Corsair H110
    Avira
I would lean toward the Power supply You probably want a bigger one for your next build anyway and it might solve your current problem
    Windows 8.1 Pro MC
    Asus G75VW / Z97 Pro
    Intel Core i7-3610QM / I7-4790K
    Z97 Pro
    16 GB Hyundai HTM315156CFR8C-PB PC3-12800
    nVIDIA GeForce GTX 670M (GF114M)
    VIA 6.0.10.1600
    Samsung 850 Pro 256, Samsung 850 Pro 1TB
    30 down 3 up
    Explorer 11
    NIS and Malwarebytes
Thanks for reply tried another one
the same thing
tip: the PC fans states changed to spin for 2 sec and then shuts off then on again in a loop
    Gamer11
    Intel Core i7 5930k
    ASUS X99 Deluxe
    GTX 780 Ti GHZ
    WD 2TB
    EVO 840
    Corsair 850w
    NZXT switch 630
    Corsair H110
    Avira
That's completely normal for bad capacitors.
is this normal for this condition
what about the case of the cpu ago I changed it and the PC posted again??
I want to make sure its 100% the capacitors caused this
thanks
    Gamer11
    Intel Core i7 5930k
    ASUS X99 Deluxe
    GTX 780 Ti GHZ
    WD 2TB
    EVO 840
    Corsair 850w
    NZXT switch 630
    Corsair H110
    Avira
You'll never know for sure until you swap out some component unless you can visually see bulging and/or leaking capacitors on the motherboard, but it being bad capacitors fits the symptoms much better than a bad CPU. Unless when you swapped the CPU it started posting 100% of the time for an extended period of time, it was nothing more than a coincidence.
the same thing
I have run into loop problem like that few times an it turned out that start button was getting stuck in ON position. It's aesy to check for that by disconnecting it from MB and using a screwdriver to shorten the contacts instead. One second is enough.
    Home made
    AMD Ryzen7 2700x
    Asus Prime x470 Pro
    16GB Kingston 3600
    Asus strix 570 OC 4gb
    Samsung 960 evo 250GB
    Silicon Power V70 240GB SSD
    WD 1 TB Blue
    WD 2 TB Blue
    Bunch of backup HDDs.
    Sharkoon, Silent Storm 660W
    Raidmax
    CCM Nepton 140xl
    40/2 Mbps
    WD
I checked all caps but I didnt see anyone leaking but I am not sure maybe a cap I dont see
My cpu worked in another board so its caps to my board
Thanks for all your help
the PC Now is normal fan spinning but No post
It sometimes start then stop then start again
onetime it stated and Posted and after Windows 10 logo looped again
    Gamer11
    Intel Core i7 5930k
    ASUS X99 Deluxe
    GTX 780 Ti GHZ
    WD 2TB
    EVO 840
    Corsair 850w
    NZXT switch 630
    Corsair H110
    Avira
the same thing
Thanks for joining I swapped the board out to check it and I do use a screwdriver to shorten it
but no sign of power LED H.D.D LED or beeps from speaker
    Gamer11
    Intel Core i7 5930k
    ASUS X99 Deluxe
    GTX 780 Ti GHZ
    WD 2TB
    EVO 840
    Corsair 850w
    NZXT switch 630
    Corsair H110
    Avira
