Problems Syncing Settings Between Surface Pro 3 & Desktop
    Houston, Texas
    So as my title suggests, I'm having a little bit of difficulty here syncing my Microsoft account's settings between these two devices. One of the problems is that it worked a little too well.
    I had spent a great deal of time organizing the start screen layout of my Surface Pro 3 the day I received it. My desktop computer, however, has a jumbled mess of a start screen. Going through my sync settings today, I noticed there was an option to sync the layout of the start screen of my specific account. I thought, "Great! All that time I spent organizing my Surface can be transferred to this mess of a machine!"
    I was wrong. I was very wrong. Instead of syncing my nicely planned out and organized Surface Start Screen to the desktop computer, the horrid and wretched Desktop computer start screen synced itself to my beautiful Surface.
    Before I make the same mistake twice, is there a way to choose which start screen syncs to which device? Also, I've come to terms with the fact that I'm going to have to reorganize a start screen. I only plan on doing it once and then syncing it to the other device, so would it be safer to do it via the desktop computer? Thanks in advance for any help!
    Hello Empyre, and welcome to Eight Forums.
    In your case since Surface has a different screen setup than your desktop, it may be best to turn off syncing for the Start screen on the Surface and leave it turned on for the desktop. This way the Surface will still sync everything else but it's Start screen.
    Sync Your Settings - Turn On or Off in Windows 8
    I had to do the same on my Surface Pro 2.
    Houston, Texas
    So there's no way to get the Desktop's start screen to match that of the Surface, then? Bummer. I'll definitely be keeping that Sync Setting turned off, though. I'd kick myself if I left it on while I fixed everything and had it all torn down again. Thanks for the help and the welcome, Brink! I'll go ahead and mark as solved.
    Not that I'm aware of.
Hello everybody I've been in this trouble for one or two months now, and I can't find anything helping me, so if you could help me, it would be appreciated at a point you just can't imagine ^^ Basically, I started using SkyDrive two years ago, when I installed 8 on my laptop. It was great and...
I have a Surface Pro 3 and am unable to independently set the ‘Turn Off Display After’ and the ‘Put The Computer to Sleep’ settings different from each other when plugged in to power. When I change them and save them to different settings, they both revert back to the same setting the next time I...
Problems Syncing Settings in Drivers & Hardware
Hi all, Since this is the last thread I could find about syncing I post my problem here. Last Friday I received my pro 3 i7 and I am very happy with it because it is just an awesome machine and a big step higher then the rt, surface 2, pro and pro 2 I own(ed). I am a happy camper that I could...
Hi there, I'll try to make this as short and to the point as possible. English is not my native language, so I apologize in advance for any mistakes made. Alright so I have a PC with a licensed Windows 8.1 Pro, been logging in with Microsoft account for about 3-4 months now and I absolutely...
Hello, i have a problem with latest updates on windows 8.1 with mail app. When i open it it says on the right upper corner "Syncing.." for hours and nothing happens. I am using norton internet security 2013.
Surface Icon for Desktop? in Customization
I posted this over on the Surface forums but nobody replied. I realize it's specific to the Surface tablet, but it might be a common thing used by any Windows 8 devices so I thought I'd ask here too. I had this working before I did a clean install of RT 8.1 (long story)... but I forget how I...
Solved Itunes syncing problems in Software and Apps
Hi folks, I'm having problems syncing new purchases on my new laptop with iTunes. Anyone else having issues and if so, were you able to resolve it. My PC is "authorized" but it doesn't seem to make a difference. Thanks.
