Surface Pro 3 and Power Settings Issue
    I have a Surface Pro 3 and am unable to independently set the ‘Turn Off Display After’ and the ‘Put The Computer to Sleep’ settings different from each other when plugged in to power. When I change them and save them to different settings, they both revert back to the same setting the next time I check on them. I would like Turn Off The Display set to 20 minutes and Put the Computer to Sleep set to Never when connected to power.
    Any ideas, thanks in advance.
    Win 8.1 Enterprise
    Welcome to Eight Forums,
    Please try this..... go to Device Manager and expand Network Adapters. Double click on the problem network adapter select the Power Management tab. Make sure that "Allow the computer to turn off this device to save power" is check off.
    Quote Originally Posted by 2xg View Post
    Thanks, I have that checked off, seems to be Connected Standby "feature": Turn Off Display After and the Put The Computer to Sleep Settings Problem - Windows Phone Central Forums
    Quote Originally Posted by richs View Post
    Just wanted to confirm this. I got my SP3 in June, and was horribly confused for a while about this behavior--even had a chat support session with a MS person--who did not really help me, and asked questions in the context of whether I was having power profile issues--which I was not, but was a problem at the time. After more research, I confirmed, this behavior is due to the new Connected Standby feature. Which I really wish, if the system is getting power, that turning the display off really just turned the tablet screen off but left the system otherwise on and functioning. Le sigh...
    Windows 8 Pro
    This was driving me insane until I figured this out. Turn on Hyper-V and connected standby goes away. Not a big deal. Still boots up quick. Now you have access to other power schemes. And you can finally set your monitor to turn off while the Surface is still wide awake.
So as my title suggests, I'm having a little bit of difficulty here syncing my Microsoft account's settings between these two devices. One of the problems is that it worked a little too well. I had spent a great deal of time organizing the start screen layout of my Surface Pro 3 the day I...
Best Power Settings - Win 8 Server in Performance & Maintenance
Hi all, Please could someone advise, direct me to some advice on what the best settings are if I am using Windows 8 as a server. I was it to be as eco as possible shutting off when not in use but quickly booting when necessary. I have heard of software's that do this but don't know; 1)...
Power Settings Not Maintained in Performance & Maintenance
Hi, I have made a cutomised power configuration for my laptop, which prevents it from shutting down etc, when it's on main power.. It works OK, but keeps resetting itself to the Balanced (default) configuration after a couple of days. Any advice please?:think:
Solved Can't switch power settings in Performance & Maintenance
Hi, My little sister just got a new Asus X201E Laptop with Windows 8. The problem is that it is not possible to switch between a "power saving" and "performance" profiles. Every time I try to select the "power saving" mode, it jumps back to the "performance" :( The screenshot is in Czech but...
What is the difference between balanced power setting versus performance power setting? I've been doing some googling about but there are only some references to laptops for actual performance gains. There was no clear answers as to what those settings are for each.
I have a power settings GPO set with the following settings: - Turn off the display after 15 minutes I also have a screensaver GPO that turns on the blank screensaver after 30 minutes. It's set to display the logon screen on resume. In Windows XP & Windows 7, this works flawlessly....
